kgg Posted February 27, 2023 Report Posted February 27, 2023 (edited) I find it interesting that similar machines to the Juki TSC-441 heavy duty sewing machines there are variations of how the top thread path to the needle varies. I wonder what are the pro's and cons are??? 1. Juki TSC-441: i) I couldn't find good photo's for the Juki TSC-441so the info is from the Juki instruction manual. The top thread goes through the top tension eyelet and through the tension disc's then down to the lower tensioner disc and then the thread wraps around 1 1/2 times the disc of the lower tensioner and exits the lower tensioner eyelet before going to the check spring. There is a) no wrapping around the top tensioner and doesn't exit the eyelet before going onto the lower tensioner. b) doesn't go through the lower tensioner eyelet before being wrapped 1 1/2 times. 2. Cowboy: photo 1 and 3 ( https://www.youtube.com/watch?v=rCppWRvkyfAi) i)The top thread goes through the top tension eyelet and through the tension disc's then down to the eyelet of the lower tensioner and then the thread wraps around 1 1/2 times the disc of the lower tensioner and exits the lower tensioner eyelet before going to the check spring. There is no wrapping around the top tensioner and doesn't exit the eyelet before going onto the lower tensioner guide. 3. Cobra: photo 2 and 3 ( https://www.youtube.com/watch?v=HoPadkFEEJ4i) The top thread goes through the top tension eyelet and wraps around the tension disc's then and exits through the top tension eyelet before going to the lower tensioner eyelet and then wraps around 1 1/2 times (their are a couple of video's showing the thread wrap 2 1/2 times ) before going back through the lower tensioner eyelet before going through the check spring. 4. Techsew: photo 3 and 4 ( https://www.youtube.com/watch?v=stGYaZ7GjPgi) The top thread goes through the top tension eyelet and through the tension disc's then down to the lower tensioner disc and then the thread wraps around 1 1/2 times the disc of the lower tensioner and exits the lower tensioner eyelet before going to the check spring. There is a) no wrapping around the top tensioner and doesn't exit the eyelet before going onto the lower tensioner. b) doesn't go through the lower tensioner eyelet before being wrapped 1 1/2 times. kgg Edited February 27, 2023 by kgg missing references Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Burkhardt Posted February 27, 2023 Members Report Posted February 27, 2023 I looked for the destructions for mine and could only find the really blurry ones they emailed me. So I think I must have got some for mine when I got it cause there is no way I could've threaded from the emailed ones. I go through the guide pin(1 hole) and then to eyelet, around tension disc clockwise then back out the eyelet down to the next eyelet, around twice then back out the eyelet to the take up spring. Right or wrong it's how I threaded mine from day 1. Quote
Contributing Member Tim Schroeder Posted March 8, 2023 Contributing Member Report Posted March 8, 2023 I think exiting thru the first eyelet and then going thru the second eyelet before wrapping around the second tensioner just adds unwanted tension. I looked up every 441 clone I could find and Cobra is the only one who threads their machine this way. Quote
Contributing Member Tim Schroeder Posted March 8, 2023 Contributing Member Report Posted March 8, 2023 I went back and threaded my machine like Cobra does, and the thread is rubbing on the tension release arm/lever after exiting the first tension eyelet. I wouldn't think that would be correct. It obviously doesn't make any difference to the Cobra people. The original Juki machines aren't threaded this way. Anybody figure out why our edit button disappeared? Anybody that lost their edit button running Windows 11? Quote
Moderator Wizcrafts Posted March 9, 2023 Moderator Report Posted March 9, 2023 Tim, I don't double up through the top thread guide. I set it as low as it will go behind the disks and feed through it, up and inside the top disks, then down through the eyelet over the bottom roller, around ccw 2 turns, then up through the same eyelet and on to the check spring. If that makes the top tension hard to adjust, I don't go through the roller eyelet on the way to the check spring. This would be when I dumb down my machine to sew with thin thread and thin needles into thin material. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted March 9, 2023 Author Report Posted March 9, 2023 7 hours ago, Wizcrafts said: This would be when I dumb down my machine to sew with thin thread and thin needles into thin material. Your article, Dumbing down a Cowboy CB4500, Cobra Class 4, or similar harness stitcher ( https://www.rw-leatherworks.com/blog/2019/02/dumbing-down-a-cowboy-cb4500-cobra-class-4-or-similar-harness-stitcher.html ) , is a really good. If possible any chance of a couple of photo's? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted March 9, 2023 Moderator Report Posted March 9, 2023 7 hours ago, kgg said: Your article, Dumbing down a Cowboy CB4500, Cobra Class 4, or similar harness stitcher ( https://www.rw-leatherworks.com/blog/2019/02/dumbing-down-a-cowboy-cb4500-cobra-class-4-or-similar-harness-stitcher.html ) , is a really good. If possible any chance of a couple of photo's? kgg Right now (March 9, 2023), my Cowboy, 4 other sewing machines and a Fortuna skiver are 20 miles away, stored in my business partner's workshop in Montrose, Michigan. We have been out of business since December 31, when the building hosting us closed on short notice. Hopefully, we can find a new host soon! I will take photos, and maybe videos, once we get setup in a new building. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted March 10, 2023 Author Report Posted March 10, 2023 15 hours ago, Wizcrafts said: Right now (March 9, 2023), my Cowboy, 4 other sewing machines and a Fortuna skiver are 20 miles away, stored in my business partner's workshop in Montrose, Michigan. We have been out of business since December 31, when the building hosting us closed on short notice. Hopefully, we can find a new host soon! That is a terrible situation. Hopefully you find a spot soon. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
