CFM Frodo Posted March 1, 2023 CFM Report Posted March 1, 2023 My bobbin older is making me angry!!! y tension spring screw is screwed in all th way, it can not get any tighter but my damn thread is as loose as a goose I pulled the thread out and tried to “re-set”’ it. Nope, still loose bobbin holder is new, screw is new#69 thread any suggestions? Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members TomE Posted March 1, 2023 Members Report Posted March 1, 2023 54 minutes ago, Frodo said: My bobbin older is making me angry!!! y tension spring screw is screwed in all th way, it can not get any tighter but my damn thread is as loose as a goose I pulled the thread out and tried to “re-set”’ it. Nope, still loose bobbin holder is new, screw is new#69 thread any suggestions? Don't know what machine you're using, but I saw a suggestion for #92 thread in a 441-type machine: reverse the bobbin in the shuttle so the thread draws out the "wrong" way to increase friction and tension. Quote
kgg Posted March 1, 2023 Report Posted March 1, 2023 1 hour ago, Frodo said: tension spring screw is screwed in all th way, it can not get any tighter The actual piece of metal, spring, that the thread goes under to get tension is probably bent away from the bobbin case from applying to much tension on the tension screw or poor metal being bend away from the bobbin case body. Sometimes happens when to large a thread is used or the screw is over tighten. Try to re-straighten the spring but you are probably going to have to get a new one or make one. If this is a fairly common problem for the "Tinkers Delight" and some people just make a new out of better metal. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
CFM Frodo Posted March 3, 2023 Author CFM Report Posted March 3, 2023 Good advice, I loosened the screw tapped the spring gently. The result was more tension Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
PastorBob Posted March 3, 2023 Report Posted March 3, 2023 3 hours ago, Frodo said: Good advice, I loosened the screw tapped the spring gently. The result was more tension Ha ha . I knew an old guy, oh yeah, he was old...he helped us out on the farm when I was a kid. Anytime anything mechanical or electrical would give him fits, he would pull out his trusty hammer and give the thing a few taps. Generally, whatever wasn't working would begin working as it should. Glad it was an easy fix. Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
