I spent a couple hours in the shop today, working to bring the two dimensional design to life.  The first hour or so, tooling on the design.  Still not where I want to be, but happy that my skills have improved a lot.  I didn't spend a lot of time with the lifters like I would have on something that would see a lot of light.  This will sit on the shelf in my private workshop.  But I still tried to create that 3D effect as much as possible. :)
The next hour or so was spent with a small detail brush, working on dying the pattern.  Of course, I didn't work on the panel IN the box.  I had it on the workbench.  I will let the dyes dry, then put on a resistance coat, and antique.  That will tone down the colors, and highlight the detail.  A coat of Watco oil will provide finish and a richness to the leather as well.  Once I have applied a couple coats of finish, I'll wax it.  It should compliment the mahogany box once IT's done.
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Worked in the shop for a while today, Sanding the maple insert by hand.  Started at 120, then 220, and then to 325 grit. This was 120, but by the time I was all the way thru the progression it was looking pretty good.
I always save the offcuts from the builds until the project is completely finished, and there is a reason.  I use them to test various aspects of the finishes, or in case I need to use the plug cutter to make plugs or cut wedges.  Always nice to match the wood.  In this case, I wanted to decide if the Golden Oak base would improve the look of the maple, or to go with JUST the natural.  A test piece would answer that question.  Finished on side of the offcut in the combo and one straight.  Both Miss T and I preferred the fuller, more rich color of the Golden Oak combo.
So, I finished sanding out the inlay, including filling a pinhole in one end prior to sanding... then wiped it down to remove the sanding dust.  A base of Golden Oak Watco Oil followed by two coats of Natural Oil... and left to dry.
Then, I turned to the boxes.  First they were clamped to the bench and the high areas were planed to match the profiles of the other edges.  Then I used a molding tool to roll the edges and corners.  Finally everything was sanded to blend the edges and corners.  I left the edges for the inside corners sharp as they will receive the inlays.
I will do some final hand sanding tomorrow, and then we'll be ready to make those (Pucker Factor) Separation Passes over the table saw.  Once that is done, I'll touch up the freshly cut edges and then move to the final phases.  The "Sewing Room" box will get inserts to align the top and it will simply sit on the top of the box.  The Letter Box will get hinges and a latch of some sort.  The letter box will also get interior treatments.  A bit more still to come.
A peek at the leather insert... I spent an hour on IT yesterday as well.  Antiquing and putting on two coats of sheen finish.  Looking pretty good.  Toned down the colors.  I put the antique on heavy and then slowly worked it off using q-tips, taking much more off on the high areas then concentrating on some of the lower areas to insure it didn't stay too dark.  I'm fairly happy. :rolleyes:
Back out today, ready to pucker up.  The first step was to set up the distance from the fence to the blade.  Again, saved the cutoffs and used a piece with the dados to set up.
I made the first passes on the LONG side, on both boxes, then cut spacers from the right thickness of cardboard, and wrapped the boxes in tape, high enough that the tape wouldn't interfere with contact of the fence.
Then prepared to cut the short sides.  One hand and the featherboard would insure constant contact and position, the other would use a push stick to guide the box across the blade for safety.
Once the four sides are cut, you have boxes with actual tops and bottoms.  Unless you are perfect or you have some type of jig, you'll have some minor issues to contend with.
Some work with the sander and planes took care of that.  Now ready for some finish sanding and then the application of the natural oil.  First I'll need to add the last items to each box.  The guides to hold the lid center on the sewing room box, and the insert for the top for the letter box and the dividers on the bottom to keep the letters in place.  Those will wait for the next session.
Got out over the last couple days, a short session here and short session there.  We have had contractors out to run power to the new small run in barn and feed room.  Took a long while to get them out.  We have been busy with that, and I had other issues, but knocked out a few things.  Drawing close to the end, so one thing I had to remember to so, was a neat little trick.... I took some black paint and painted a line down both ends of the area where the leather insert will go.  With all the tooling, it's just a fraction short.  This will prevent that bright white background from showing through.  Can't paint the WHOLE thing black or the contact cement won't hold as well.
Then I spent about two hours with small squares of sandpaper doing the finish sanding on all four sections of the two boxes.  Any blemishes were sanded away.  Not furniture, but I wanted them to look as nice as possible. :)  Next I cut the strips of leather that will become the index strips inside the lid to the letter box and VERY carefully stamped the letters on the strips.  They represent their positions in the box.
Since I had to run to the doc about a possible ear infection that made the whole left side of my face and jaw hurt, I didn't get much done today, but I wanted to knock out the oiling of the pieces.  All four box components and the two reference strips got their first couple coats of oil.  They will dry overnight and I'll likely put a second coat on them tomorrow; AFTER I put the dividing rails in the letter box bottom between the letters, and the top between the reference strips.
The sewing box oiled, (The strips are in the pic as well.)  The grain on this box is really nice.
The letter box doesn't have as nice a grain, but the mahogany is still nice looking, and both will look good once put together.
More work tomorrow.
Session this morning, now that the barn electrical project is done for the wife.
The first portion concerned the reference strips now that the oil has dried and we have a resistance coating.
I put a nice coat of antique on the strips, ensuring that every letter was fully filled and let it sit for about five minutes.  Then, wiped off the excess, careful NOT to wipe the antique out of the letters.  This darkened the natural leather and filled / highlighted the letters.  I think it turned out great.  I let it dry while I worked on the dividing strips, then put on a coat of finish.
I made two pairs of dividing strips from scrap walnut, measured to be the appropriate height.  One set for the letter tray, and a set to fit between these reference strips.
I rolled the top edges for aesthetics, and then coated them with natural watco and set them aside to dry.  We are very near the final assembly point.
Another session, assembly in progress. :rolleyes: Started with the letterbox bottom rails.  They will keep the letters in the proper place and order and leave a space below the letters to store the handles.
It worked out well, though I didn't like the larger stamps in here so they will live in a tray in the leatherwork bench drawer.  I don't have that many at this time, so no biggie.
Next up was making sure I oriented the under side of the top correctly then assembled the reference strips and spacers for that... They turned out very nice, and the walnut strips accent the antiqued letters on the strips perfectly.
