Members Skifunk2 Posted March 30, 2023 Members Report Posted March 30, 2023 (edited) I have done leatherwork by hand for a few years now, and was recently able to obtain my grandfathers S29k72 leather patcher from his old shoe store. It hasn’t been used for many years, and since he’s passed away I have very little assistance for my questions. My biggest question is the presser foot comes up extremely high, thus not moving the Material. I have already tried to adjust the settings on the back of the machine to no avail. I have attached a picture for reference as to how high the foot comes up at the top of the stitch. Any help would be greatly appreciated! Edited March 30, 2023 by Skifunk2 Quote
Members shoepatcher Posted March 30, 2023 Members Report Posted March 30, 2023 The flat screw on the other end of the shaft that has the wing nut for adjusting the walk is off. That has to be loosened. I always replace that screw with an Allen screw 1/2" x 24tpi. Easier to adjust and you can tighten it down more on the shaft. Once loose, set walk with wing nut to lowest walk and slightly tighten straight slot screw to get the walk adjusted. Next go to highest walk with the wing nut. (letter H on the gauge) and adjust it so foot just comes up under needle clamp. You will get the knack of it with a little practice. glenn Quote
Members Skifunk2 Posted March 30, 2023 Author Members Report Posted March 30, 2023 Thanks, I will try that adjustment order and see what happens! Quote
Moderator Wizcrafts Posted March 30, 2023 Moderator Report Posted March 30, 2023 I will add to make sure that the manual hand lift lever is all the way down before you try adjusting the foot lift components. I've seen people go crazy trying to get the foot down on the leather when the manual foot lifter is engaged! They literally needed to consult a therapist afterward! ;-) Another way to tell that the manual lifter is engaged is if the top thread has almost no resistance when you pull it out the bottom, or through the needle's eye. This is because a properly set machine separates the top tension disks when the foot lift lever is raised up. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Brewerkel Posted April 5, 2023 Members Report Posted April 5, 2023 The manual is available online if you don't have one. Aside from the excellent advise you received above, the manual is handy if you need to order parts. The 72 is a beautiful machine when properly maintained and tuned. Your grandfather was a wise man chosing that model. Happy tinkering and happier sewing! Quote
CowboyBob Posted April 5, 2023 Report Posted April 5, 2023 1 hour ago, Brewerkel said: The manual is available online if you don't have one. Aside from the excellent advise you received above, the manual is handy if you need to order parts. The 72 is a beautiful machine when properly maintained and tuned. Your grandfather was a wise man chosing that model. Happy tinkering and happier sewing! Here's a manual. Singer_29K71_72_73_Manual_hi_res.pdf Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Skifunk2 Posted April 6, 2023 Author Members Report Posted April 6, 2023 Thanks everyone! This has been more than helpful so far. It has been a work in progress, and I think I'm starting to get it dialed in. The practice stitches are definitely improving with each adjustment and cleaning/oiling that I do. Hoping to have it "finalized" this weekend. Then it will be on to turning my attention to the treadle and adjusting that back to a strictly foot and not motorized... Quote
