kgg Posted April 11, 2023 Report Posted April 11, 2023 31 minutes ago, Moti said: I don't understand both are the same needle system? They are different needle systems. They are the same diameter (2.0 mm) with different lengths made to fit different machines. The 134-35 length is 38.1mm from the end to the center of the eye and the 134 is 33.9. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Moti Posted April 11, 2023 Author Members Report Posted April 11, 2023 So which one is System 134? Quote
Members Moti Posted April 11, 2023 Author Members Report Posted April 11, 2023 (edited) Adler 269 in the book is 134 only o sorry 134-35 only Edited April 11, 2023 by Moti Quote
Members Moti Posted April 11, 2023 Author Members Report Posted April 11, 2023 1 hour ago, kgg said: They are different needle systems. They are the same diameter (2.0 mm) with different lengths made to fit different machines. The 134-35 length is 38.1mm from the end to the center of the eye and the 134 is 33.9. kgg Thanks Quote
kgg Posted April 11, 2023 Report Posted April 11, 2023 Just now, Moti said: So which one is System 134? The one for your machine that the manufacturer recommended, which was the 134-35 needles so the Groz-Beckert should be the ones. The manual I am referencing is https://www.manualslib.com/manual/461721/Duerkopp-Adler-269.html?page=4#manual kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Moti Posted April 11, 2023 Author Members Report Posted April 11, 2023 And all subclass the largest size needle is 130 21 is 125? 22 is 140 So what is 130? Quote
Members Moti Posted April 11, 2023 Author Members Report Posted April 11, 2023 (edited) Ok sorry I messed up, I'll do some homework, thanks for everything Edited April 11, 2023 by Moti Quote
kgg Posted April 11, 2023 Report Posted April 11, 2023 (edited) 54 minutes ago, Moti said: 21 is 125? 22 is 140 So what is 130? According to Schmetz Needle Size Designations (https://www.schmetzneedles.com/pages/needle-size-designations ) A number # 19 is a 120 metric needle this is good for A number # 20 is a 125 metric needle A number # 21 is a 130 metric needle which is good for V92 (Tkt30) A number # 22 is a 140 metric needle kgg Edited April 11, 2023 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
