Members Burkhardt Posted May 11, 2023 Members Report Posted May 11, 2023 As @Wizcrafts said take off the bottom cover by the base where it bolts to the stand where you would adjust the timing. There are I believe 3 spots to oil that you have to rotate the wheel to be able to get each oil spot accessible and leave paper towels or rags in for access oil as there are parts to oil above them also. Quote
Members Lakil7 Posted May 12, 2023 Author Members Report Posted May 12, 2023 Great advice. I'm taking it all in and implementing the recommendations. I haven't started on my new project yet. I going to give the machine a good oiling in the all the places mentioned. I am running the machine without actually sewing anything, just to get the oiled parts well lubricated. I will give an update when I start my project on how the machine is performing. Thank you all so much for your input. Much Appreciated!!!!!!!! Quote
Members Lakil7 Posted May 19, 2023 Author Members Report Posted May 19, 2023 Hello to all, I want to state that at the moment my machine is working well. Hope it stays that way, and that the issue of jamming does not return. Thanks to all of you for your input, insight and help. One other issue I have is that my bobbin winder does not work smoothly. It stalls while I am winding the bobbin. I would have to constantly lift and depress that square paddle part that clamps down on the bobbin, to get the it to start moving again. Does anyone have any thoughts or remedies. Quote
