Moderator Wizcrafts Posted April 28, 2023 Moderator Report Posted April 28, 2023 18 hours ago, NEWAY said: Just curious how much would it cost to change out parts so that it will suit the work that I intended it for? Even if I have to spend another $900 I think it would still be a better deal than the other run down 335 asking for $1800? No matter what parts you swap out, you will not be able to get a 4 motion feed dog on this binder machine. The feed dog only moves forward and backward on this machine, which was designed to sew bias tape binding onto the edges. That means that the feed dog may actually fight the feed as it slides forward directly against the bottom of the leather. If you plan to apply edge binding, this is a great machine. Otherwise, if you want it for normal sewing operations, you'll need a 4 motion feed dog, aka: a drop feed machine. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members NEWAY Posted April 28, 2023 Author Members Report Posted April 28, 2023 17 hours ago, kgg said: I used the specifications for the PFAFF 335 from the pfaff industrial website which is for the newer model ( pfaff-industrial.com/en/portfolio/sewing-machines/cylinder-arm/pfaff335 ) which lists the needle system as 134-35LR and needle size from 80-100. Be careful with what you see as you need to know how thick and what type of leather as well as what modifications were made to the machine. Like @Wizcrafts said a used Consew 227R would be better. Another consideration would be a Class 341/1341 machine like a Juki 341 or 1341 or a clone. kgg Good point, I didn’t think that there could be such big differences between different variants of 335. Haven’t seen any Consew on my part of the globe. Guess I will have to wait. Thanks! 6 hours ago, dikman said: I concur, if you don't want the 335 to use as a binder then you will be better off buying a "conventional" cylinder arm machine, one with reasonable clearance (at least 3/8") under the feet. In the long run it will be more versatile and a better investment. Yup! I didn’t realise that there are such big differences between different variants of 335, so the wait continues. Thanks. Quote
Members NEWAY Posted April 28, 2023 Author Members Report Posted April 28, 2023 1 hour ago, Wizcrafts said: No matter what parts you swap out, you will not be able to get a 4 motion feed dog on this binder machine. The feed dog only moves forward and backward on this machine, which was designed to sew bias tape binding onto the edges. That means that the feed dog may actually fight the feed as it slides forward directly against the bottom of the leather. If you plan to apply edge binding, this is a great machine. Otherwise, if you want it for normal sewing operations, you'll need a 4 motion feed dog, aka: a drop feed machine. Very well explained! Thank you! So the wait continues… Quote
kgg Posted April 28, 2023 Report Posted April 28, 2023 5 hours ago, NEWAY said: Haven’t seen any Consew on my part of the globe. Where are you located so other machine options that are more common in your area can be suggested. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members NEWAY Posted May 29, 2023 Author Members Report Posted May 29, 2023 On 4/28/2023 at 12:53 PM, kgg said: Where are you located so other machine options that are more common in your area can be suggested. kgg I am based in Austria. Just picked up a Adler 49-1 for price of a decent dinner. May not meet my needs but it is a good start for me to familiarise myself with the machine and prepare me for the next purchase. Quote
kgg Posted May 29, 2023 Report Posted May 29, 2023 30 minutes ago, NEWAY said: Just picked up a Adler 49-1 for price of a decent dinner. Looks in great shape and a right handed machine to boot, very unusual these days. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members dikman Posted May 29, 2023 Members Report Posted May 29, 2023 That is a great-looking machine! I love the exposed mechanics. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members NEWAY Posted May 30, 2023 Author Members Report Posted May 30, 2023 6 hours ago, dikman said: That is a great-looking machine! I love the exposed mechanics. Just found out that it is similar (or possibly identical triplets) with the Singer 18 and Pfaff 24. Quote
Members NEWAY Posted May 30, 2023 Author Members Report Posted May 30, 2023 9 hours ago, kgg said: Looks in great shape and a right handed machine to boot, very unusual these days. kgg It is indeed after spending half a day dousing it with sewing machine oil and managed to free it from its frozen state. It appears that it has only been lightly used (from commercial machines perspective) everything move smoothly except it is not feeding, the feeddog is slight worn but it moves, roller is free, perhaps roller need special set up? 11 minutes ago, NEWAY said: Just found out that it is similar (or possibly identical triplets) with the Singer 18 and Pfaff 24. Quote
Members dikman Posted May 30, 2023 Members Report Posted May 30, 2023 When the roller is down is it resting on the feed-dog? Does it have any downward pressure to hold the material against the feed-dog? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
