Hello!
I'm into making tack for my horse and I've been seeing a lot of really pretty bronc nosebands with names in fancy fonts that look to be in perfect uniform. How are people able to carve such nice fonts? is it just done with a swivel knife and pattern piece? This is probably a dumb. question but I'm still learning when it comes to tooling leather.
benlilly1 uses stamp letters from Turner laser works for her dog collars. They look great and I don't remember them being terribly expensive.
Check it out.
Not so retired RN. Living on the Washington Peninsula.
Thanks. I have a set of stamps but I’m more interested in how the larger names are written with different types of fonts and styles if that makes sense? I don’t want to post a picture as it would be one off google and not my own work.
While I don't claim to be very good at letters here is what I do.
Choose the font  and size you want
Print what you want out ( resize if you need to )
Once I have it like I want I cover both front and back with packing tape
Transfer to cased leather with ball end stylist , cut with swivel knife , bevel and do any other tooling you want
The fancier the font the more difficult it is for me !!!!!!
:17:
I do pretty much the same thing. This was made with fonts I printed off, taped, traced, carved with the swivel, and beveled. Just like Gezzer said
(Blue spot there to cover up last name, per customers request for privacy)
Edited by Fraulein
Gezzer and Fraulein thank you so much! That was exactly what I was wondering. I sure it's a lot harder than it looks getting letters to look. For beveling is it ook to just stick to the basic beginners kit tools? I'm just getting into tooling a bit and just have the basic checkered bevel.
It's a little tricky to get the hang of it, but you can definitely do it! Just make sure and do some practice pieces. I've used the basic beginner bevelers and it's turned out great. If you use a checkered beveler the antique paste will stick in a little more around the letters. The pic above was done with a smooth beveler. Either is fine and I use both, just depends on the effect I'm going for.
The only bevels I have are from starter tool kits , like most tools they will work just fine . The more you use them the more things  you will find you can do with them .  Some times you will have to tip a bevel and just use a small portion in tight places .   The pic I posted was done with a Z-B 701 .........  came with a cheap starter kit .
Like Fraulein said      PRACTICE  is all it takes .
So Tandy makes alphabet Craftaids, which are plastic templates to transfer a design to cased leather.  I used them as a kid (before desktop computers).  Now I just create the design in illustrator, print it out, and transfer to leather by tracing the design.
Greetings,
Here is what I use to emboss words, letters into Veg Tanned leather.  I use this method because a LOT of my work involves letters:
https://drive.google.com/file/d/1GLfvsGGEUyjaOgc1dJr75GgUTDiegBah/view
...and an older version
https://drive.google.com/file/d/1qgV6aH_FkHa5lBX_kNceroW2elQju_XW/view?usp=sharing
Hope this helps
Edited by stelmackr
Bob Stelmack
Desert Leathercraft LLC
Former Editor of the, RawHide Gazette, for the Puget Sound Leather Artisans Co-Op,  25 years of doing it was enough...
