Hi Guys,
I'm looking for a partslist of a Pfaff 138-6. (As shown)
Normally it's sort of explosion drawing, where You can work out how parts go togehter.
Or any advise how to loosen the needle bar for adjustment would be greate2c1fe465c4a85154b74bba571d6d4cb.jpg too.
Would appreciate any help.
Thank You all...
"A stitch in time saves nine."
Remove the face plate. The needle bar is clamped by 1 screw which is visible from the front. Rotate the hand wheel until you can see it through the hole. See pictures.
Edited by Constabulary
Aaaaaah there it is....little sucker.....hidden on the other side deep in a hole !!
Thank You so much, I think I need new glasses too !!
