Moti Report post Posted November 7, 2023 I recently bought an Enduro elite sm1050-2pf motor, I tried to assemble it for my 204 370 sewing machine, and I keep getting error e1. I read the booklet and checked everything is fine, but it continues and the motor stops every time the error message pops up, i tried to take the belt off the machine and the motor works ok when i put the belt back again the same problem can someone help me please Quote Share this post Link to post Share on other sites
chrisash Report post Posted November 7, 2023 Is the motor and machine earthed Is the power supply stable any flickering lights in the house/workshop If you know any electrician they could put a scope on the mains supply, if not maybe change to board as suggested contact your motor supplier Quote Share this post Link to post Share on other sites
Moti Report post Posted November 7, 2023 I tried all this too, I think the electricity is good, because I disconnect the belt from the sewing machine, then the motor works perfectly fine thanks Quote Share this post Link to post Share on other sites
Moti Report post Posted November 7, 2023 The only thing I played with before I connected the motor was the Treadle Sensor Quote Share this post Link to post Share on other sites
fibersport Report post Posted November 7, 2023 Is the motor the same voltage and frequency that you have at your outlet? Here in the USA most home electrical is 120 volt 60 Hz, I'm not sure what it is in Israel, just make sure you have the correct motor. Quote Share this post Link to post Share on other sites
Moti Report post Posted November 8, 2023 Yes Israel use 220 v 50 hz The only thing I played with before I connected the motor was the Treadle Sensor Quote Share this post Link to post Share on other sites
Burkhardt Report post Posted November 9, 2023 Try putting it back to where it was when you got it and see if the issue is still there. Quote Share this post Link to post Share on other sites
fibersport Report post Posted November 9, 2023 Wondering if your linkage is set correctly, you might just be turning the motor on but not moving the lever down enough to actually speed it up, that might explain why it runs without a belt but not when you install the belt - no load vs. load on the motor. Quote Share this post Link to post Share on other sites
Moti Report post Posted November 9, 2023 49 minutes ago, fibersport said: Wondering if your linkage is set correctly, you might just be turning the motor on but not moving the lever down enough to actually speed it up, that might explain why it runs without a belt but not when you install the belt - no load vs. load on the motor. Any I got a new one and it's working very good with the needle position and the foot lift now So I put set the linkage the same as the new one tomorrow will check the first one again Thanks allot everyone Quote Share this post Link to post Share on other sites
