Members Seamyher89 Posted December 8, 2023 Members Report Posted December 8, 2023 Please assist. My bobbin hook is not spinning at some points. I will move it around and sometimes it will spin and others it won't. I'm hoping there's just something stuck down there. https://www.reddit.com/u/verniyah/s/4jdO9hBg9K Quote
Members Seamyher89 Posted December 8, 2023 Author Members Report Posted December 8, 2023 The gear in the back is also clicking and jumping at certain points, as you can see in the video when I am hand cranking the machine. The hook also spins at certain points. It makes me wonder if there is just a jam somewhere, if the gear was absolutely done then the hook wouldn't spin at all, right? https://www.reddit.com/u/verniyah/s/xqP3ehouwk Quote
CowboyBob Posted December 8, 2023 Report Posted December 8, 2023 (edited) @Seamyher89 Take the bobbincase out & unjam the hook. Then take the cover off under the arm,I think you jammed it & stripped the plastic gear that drives the hook. Edited December 8, 2023 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Seamyher89 Posted December 8, 2023 Author Members Report Posted December 8, 2023 (edited) Also the machine is bought used so I could not say what cause this problem. Edited December 8, 2023 by Seamyher89 Quote
Members Seamyher89 Posted December 8, 2023 Author Members Report Posted December 8, 2023 @CowboyBob Yes, I did take the case out so now it's just taking the cover off under the arm and checking that out? Should I see if anything got stuck under the bottom? I bought this machine used so I have no idea what the other person did to damage it, kind of lost on this but will definitely try your suggestion Quote
CowboyBob Posted December 8, 2023 Report Posted December 8, 2023 2 minutes ago, Seamyher89 said: @CowboyBob Yes, I did take the case out so now it's just taking the cover off under the arm and checking that out? Should I see if anything got stuck under the bottom? I bought this machine used so I have no idea what the other person did to damage it, kind of lost on this but will definitely try your suggestion Yes,there could be thread in the groove of the bobbincase that rides in the hook.You'll see the larger black gear that might have bad teeth. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Seamyher89 Posted December 8, 2023 Author Members Report Posted December 8, 2023 @CowboyBob Wowwww I may have found the issue. Check it out at the link. Is this a gear? Does it just need replacing? I wonder if I could just take the one off of my Singer Heavy Duty https://www.reddit.com/u/verniyah/s/wJtU4MAflA Quote
Members Seamyher89 Posted December 8, 2023 Author Members Report Posted December 8, 2023 I bought the machine used so attempting to fix it. JUKI HZL F400 https://www.reddit.com/u/verniyah/s/HgS1CBuG6r Quote
Northmount Posted December 8, 2023 Report Posted December 8, 2023 3 hours ago, Seamyher89 said: I bought the machine used so attempting to fix it. JUKI HZL F400 https://www.reddit.com/u/verniyah/s/HgS1CBuG6r @Seamyher89 Please keep these related posts in one thread instead of starting a new thread each time you find something related to your machine's problem. I have merged your 2 other threads into this thread. Quote
CowboyBob Posted December 9, 2023 Report Posted December 9, 2023 21 hours ago, Seamyher89 said: @CowboyBob Wowwww I may have found the issue. Check it out at the link. Is this a gear? Does it just need replacing? I wonder if I could just take the one off of my Singer Heavy Duty https://www.reddit.com/u/verniyah/s/wJtU4MAflA I don't the your pics on the link you posted,try posting them here. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
