Members queenslander Posted January 13, 2024 Members Report Posted January 13, 2024 Hi folks and good morning from Australia I have a slight problem with my Cowboy CB4500 and servo motor The machine is 10yr old but has done very little work and most of that is 8/9oz.Today I have gone to sew and switch the power on everything lights up as per normal the LED on the front has these little [ ] things that just revolve around the screen as per normal no noise at all, have pulled all power connections (plugs) out put them back in switched power off for a while switched it back on again I am at a loss as I only used it a month ago and it was perfect. The only thing I have put it down to is we did loose power for about 2 days due to flooding in the north of the country and I did hook up a generator for that time and the machine was plugged in to the wall maybe a power spike from the generator, but then it should not switch the LED screen on.I DON’T KNOW Quote
kgg Posted January 13, 2024 Report Posted January 13, 2024 On 1/13/2024 at 12:12 AM, queenslander said: I have a slight problem with my Cowboy CB4500 and servo motor Expand Have you checked the fuse on the servo motor??? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members queenslander Posted January 13, 2024 Author Members Report Posted January 13, 2024 Hi keg Thank you for your reply and did check the fuse all ok.I then started to have a good look around and found the speed sensor lever on the side of the servo motor was loose so undid the 4 screws and took the panel with the lever attached and then found the problem The black plastic blade that moves in the u section of the optical sensor was just layered in the housing so put it back on the shaft played for a little while to get it in the right position and off she went problem solved It appears that it has never been tightened from factory Cheers to all and thanks Quote
RockyAussie Posted January 15, 2024 Report Posted January 15, 2024 Good to hear you found it. We would have been guessing for any good answers on that one. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
