Guys & gals I'm wondering? Can Tandy Eco Flo Super Sheen be used as a antiquing resist? I'm wanting to use the Fiebings antique gel & curious if this is possible. I'm curious if is leave it full strength or dilute/thin it to 50/50.
Thanks.
Edited by DieselTech
The Tandy site says it can be used as a resist.
Not sure about the dilution needed though. They do not say it needs to be diluted when they describe the method to use it as a resist. Maybe you could test it on some scrap?
https://tandyleather.com/products/eco-flo-super-shene
I can't speak for eco flo super sheen but I did my first antique on a couple knife sheaths the other day and used  feibings antique and tan kote as a resist and it worked good, i should have a couple pictures tomorrow.
Thanks I'll do some test samples & see what happens.
I haven’t used it as a resist specifically but have used it a little bit as a finish coat. It’s already fairly thin and dried very rapidly, without leaving residue. The sheath I used it on just looks like it had some extra gloss added to the color, but it seems to resist water well nonetheless. I would guess, therefore, that it doesn’t need to be diluted, but I haven’t tried specifically yet. Do follow up with your results.
Thanks bladegrinder. I put the eco flo super sheen on full strength, then I used fiebings antique gel & let is set 10minutes then i buffed it off. It seemed to take well.
Now I'm letting antique gel cure out & will coat it 1 more time with eco flo super sheen.
We shall see how it turns out. Now dont laugh.
I put the super sheen on full strength. I will keep everyone posted.
Thanks.
As promised. Here is my very 1st poor attempt at antiquing leather. It dont look too bad.
I kinda dig the look actually. I got 1 more step of rubbing in some Skidmores leather balm.
I think that will darken it up a touch more.
This is full strength eco flo super sheen, over veg tan leather, then fiebings dark brown antique gel applied & allowed to sit 10 minutes then buffed clean.
Then I re applied eco flo super sheen to the leather panel.
Heres a couple pics.
Forgot the pictures duh!
