Hi Folks,
I've just started leather working and this is about as good as I can get my Bobbin side to look.
As stated above I am using a Singer 211G156, my thread is T135 poly (I don't have any 135 nylon right now).
I am going through 3 layers of 3-4 oz veg tan.
Any ideas on how I can make it look better?
As far as I can tell I have the tension set properly so the threads are locking in the middle.
What needle size are you using? I would guess you need a needle 1 size bigger (for a larger hole) or more top tension or less bottom tension
Edited by Constabulary
For no thicker than what your sewing a size#92 would look better because the smaller thread will hide the knot better in thin leather like this.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
The bottom appearance can be changed somewhat by using different needle shapes. If your current needle is a wedge, try a diamond point instead. They give a bold exposure on the top and bottom, compared to a slicing point. Diamond and triangle points are close to round points in thread appearance, but penetrate leather better.
Posted IMHO, by Wiz
