Guys & gals I'm wondering if any of you use a Consew 206rb-5 sewing machine for leather work?
What would be the best way to have it setup?  I was looking at having the 1hp brushless servo motor installed with a 60mm pulley & needle positioning system.
Will that make it slow enough to control or should I get a speed reducer with it as well.
Will it be a reliable machine setup with 138 thread size? Could you possibly run 207 thread thru that machine & get a reliable running machine?
What presser feet & accessories should a person get? For wallets & belt type work? Drop down guide for sure.
I'm wondering if this machine would get me by till I can get my cobra class 4? Or should I just wait & purchase the cobra class 4. Or would it be better to have both the Cobra class 4 & a Consew 206rb-5 sewing machines?
Thanks any & all help will be greatly appreciated.
Thanks.
The 1 hp brushless servo motor to my mind a 735 (1hp) watt would work nicely as a lot of us run 550 watt servo's on this class of machine. I would suggest going with a smaller servo motor pulley. It will reduce the speed. Example a 60mm pulley on the servo motor at 100 rpm's with a 100mm sewing machine pulley. The 100mm sewing machine pulley speed will be 60 rpm's. Reducing the size of the servo motor pulley to 40mm will reduce the speed down to 40 rpm's.
The most important question is how many internal coils does the 1hp servo motor have??? The less expensive brushless servo motors have 6 internal coils, mid grade have 9 internal coils and the better ones have 12 internal coils. The more coils the better the startup torque.
The next important question is what is the startup speed of the 1 hp motor, 100 or 500 rpm's???
Some people like the needle positioning feature and others not so much. Either way most of the brushless servo motors will NOT work with a speed reducer.
This will depend on how thick / tough the material you are sewing is going to be. In this class of machine they are usually rated for V138 with a top thread and in the bobbin. Some will run V207 top and bobbin but once again it depends how thick / tough the material is.
Why?? Some people like them and others not so much. I do have a drop down guide but I didn't like it so it lives in my "special" box somewhere.
Having a flatbed is always nice but it also depends on what you are mostly going to sew. If you are mostly going to sew close to or over the 3/8" thickness or use v207 or larger thread go with a Class 441 machine as a primary machine and a used upholstery class flatbed machine or vise versa. Another option is go with a Class 441 and the modified needle plates that a couple of members make.
Out of curiosity why the Cobra 4???
kgg
kgg
Thanks kgg on the lengthy informative write up. I appreciate your time & knowledge. Lol I'm kinda like the blind leading the blind at this point.
The only reason I was going to buy a cobra class 4 was of all the accessories offered for it.  Also because it seems to be the go to machine for most professionals.
Plus I think I will need a cobra class 4 for making pistol holsters & i believe that machine will run 346 thread.
I'm just trying to get a small shop up & running & debating which is going to be the way for me to go as of now. I got the money now to buy a Cobra class 4, but thought the Consew 206rb-5 might be a better machine to sew my wallets & belts on.
I have been saddle stitching everything by hand & sew everything with 346 thread & like the looks of that thread size.  Maybe it's way overkill for wallets & belts.
I thought maybe I should get the consew 206rb-5 first & then save back up for the Cobra class 4.
If there is a better machine for less money I'm all about that too. I've talked with Patrick1 about buying all the extra presser feet, feed dogs & plates for the cobra class 4 to be able to sew lighter projects with.
Do you got any recommendations or words of wisdom? I will be more than happy to listen & here yours thoughts.
Thanks.
If you end goal is for a class 441 machine buy the presser feet / feed dogs / needle plates for lighter items and purchase / make a flatbed table attachment.
Purchase a machine from whom you feel will provide the best after sale service. In the US the popular 441 clones are Cowboy 4500 and Cobra Class 4 in Canada you have Techsew 5100 and Kobe TSC-441, all of which are basically the same machine with different name tag but able to take the same accessories. They are all essentially cloned after the Juki TSC-441 however the Juki will set you back 10K.
Yes you will need a class 411 machine for holsters and all the class 441 machines will take up to V415.
Most of the class 441 machines are mounted on the pedestal style tables and probably operated while in a standing position. The major consideration with this style of stand is the possibility it being more prone to being able to be tipped over if struck the wrong way. So consider your particular situation and whether you are going to sew stood up or sat down. I choose to go with a more conventional style stand and modify it as I have dogs and when they get rough housing you never know. When you get your machine have a second person help as these are heavy buggers that are nose heavy and clumsy to handle.
kgg
kgg
Thanks kgg, Do you by chance know what a cobra class 4 weighs? I read somewhere they weigh 600lbs, do you know if this is true?
I will just stick to my original thought/plan & order the class 4 machine.
Thanks I appreciate you helping me out.
Just like the rest of the 441's the head weighs about 125 lbs. Assembled the complete unit should weight about 300 or so pounds.
kgg
kgg
Ok thanks.
346 is great .. for pulling your truck out the ditch and snow :lol:
I like 277 for holsters, and often use it on belts when they're meant to be "matching".   For a belt, like a belt, I like 207 thread is more than plenty.
The consew 206 is a reliable little machine, sews VERY well with thread size from 42 to 138.  I got mine to do 207 now and then, but usually not.  I had one of these machines, BIG mistake letting go of it.
I used mine for everything from wallet liners (like 1.5 oz chrome tanned leather) to zipper gussets (4/5 oz veg cowhide with zipper tape) to the full wallets (3/4 oz veg cow with multiple layers of lining leather).  All the way down to 42 thread for some liners, 69 thread for others, and 138 to sew the wallet together.
AND, I ocassionally "cheated" when doing a holster project.  Without going into the "why" of it all,  SOME projects I wanted HOLES but not SEWN WITH THREAD just yet.  So I rubber cement the piece together, turn OFF the machine, and HAND CRANK the wheel to "poke" the holes.  Keeps em aligned and evenly spaced.  Then went back and HAND SEW the thing together with heavier thread like a 277.  No time right now to detail all of that, but sometimes I want it held together but not YET sewn.
For great info on ALL of this... the consew (or equivalent) AND the '441' machine, contact Bob.  He'll steer ya right ;)
https://www.tolindsewmach.com/
866-362-7397
5 leather patterns
866-362-7397
Thanks for the info. I'm going to eventually buy a consew 206rb-5 it seems from all I hear a good machine.
Yeah my next adventure is going to be making holsters. I've made lots of 6 shooter holsters, but want to get into vacuum formed friction fit auto holsters.
Yeah I probably am using way overkill on my thread choices. I been reading about stitch length versus thread size & I'm way off from what most people use.
I got more to learn for sure. Lol as long as I dont sew my hand to my project I'll be ok.
Thanks again. I sure enjoy seeing your holster work.
Are you personally carrying?  No need to post here - kinda defeats the purpose of "concealed" - but send me a message with your model if I have a pattern I'll send it, first one free ;)
5 leather patterns
