Clmsaddleryandleathergoods
Fortuna band splitter motor question
Should not be no reason why you cant change it to single phase. More than likely you will need to purchase a new motor. They also make a phase convertor I believe.
I don't see why not. As DT said either buy a new motor or you could use a VFD (Variable Frequency Device) to convert your existing single phase to a 3-phase output to run the existing motor.
Is that the same as a converter?
Thanks for the info. Do you happen to know what size motors it requires?
