toxo Posted May 21, 2024 Author Report Posted May 21, 2024 On 5/11/2024 at 11:59 PM, dikman said: Inflation, my friend! It still intrigues me, being variable speed and portable. For me it's the ability to run two different grades or more importantly for me is the possibility of burnishing easily and quickly. At the moment I have a couple layers of felt giving partial results. More experiments needed, maybe a canvas belt, maybe a leather belt flesh side out. Quote
Members TomWilson Posted May 22, 2024 Members Report Posted May 22, 2024 20 minutes ago, toxo said: At the moment I have a couple layers of felt giving partial results. If you purchased a standard sanding belt that fits your machine, could you then machine stitch several layers of felt around the top surface of the belt using a stitch line near each edge? Or, stitch the length of felt layers and use contact cement to adhere it to the sanding belt? Quote
toxo Posted May 22, 2024 Author Report Posted May 22, 2024 12 hours ago, TomWilson said: If you purchased a standard sanding belt that fits your machine, could you then machine stitch several layers of felt around the top surface of the belt using a stitch line near each edge? Or, stitch the length of felt layers and use contact cement to adhere it to the sanding belt? That's what I've done Tom, just glued 3 layers of felt onto a sanding belt but it was an experiment that could be better. What I hope to achieve eventually is enough soft layers with the top layer being something like canvas or denim so I can put some compound on it so I can sink an edge into it and take the corners off and burnish to a shine all in one go. Quote
Members Tigweldor Posted March 28, 2025 Members Report Posted March 28, 2025 (edited) If you stitch through a sanding belt - your needle wouldn´t last very long at all - might even rip the thread - should be clear if you use your head. So glue is the way to go - maybe use double sided tape to quicken things up - it comes as wide as your belt and doesn´t cost an arm and a leg. Also, you would have to have your leather dyed aforehand - the polishing compound is mostly made from some sort of tallow/wax - you would not achieve proper dye penetration where the compound goes over the edge of the leather due to the soft felt wrapping around the edge - it would clog the pores of the leather and be very hard to remove once there. Now canvas would be a different matter - it is harder and has little to no "hair" that will not wrap around the edge of the leather. Just my opinion after watching the video. But this is what a forum is for - you gotta input your brain storms and get feedback that you didn´t think of yourself. I like such procedure. Greetings Hans Who has had many a thought dismissed/cancelled by valid arguments of others - most of them who had more experience on a topic than I did. Edited March 28, 2025 by Tigweldor Quote
