I stumbled into a method for removing a stuck-on lid to a jar containing acrylic edge finish:
1. Pour boiling water into a bowl.
2. Soak wash cloth/rag in bowl with boild water.
3. Place very hot soaked washcloth/rag over jar for about five minutes.
4. Twist off lid.
I think the moist heat helps out tremendously, but I suppose you could also use a hair dryer or heat gun as well.
Ed
Great idea! Thanks for the tip!
Here's one I do:
To keep the thread of my contact cement jar from gluing shut, I coat the threading with Aussie Wax (petroleum jelly would work too, I'd assume). Makes it so much easier to open the jar after it's sat for a while!
Holly Moore
Wild Rose Creations
http://www.wrcleather.com
Here's one I do:
Great idea. I always have to use the vise grips.
Speaking of Contact cement containers, is it possible to buy a replacement cap that allows for replaceable brushes. The cap-brush combos that come with the quart never seem to last long enough to use up all the glue in the container. I was thinking of just drilling a hole in the cap and using a horsehair brush from Harbor Freight and perhaps sealing around where the brush enters the hole in the cap with duct tape. However, something tells me this setup might be messy when it comes to brushing on the contact cement.
Ed
I find the easiest way to keep lids
from sticking is plastic wrap. I just
pull out a piece rip it off and place
it on the container right afore I place
the lid on. If I perchance forget , then
I get out the channel locks and crank
it off.Only thing is if you have a glass
jar you best be very careful on how
tight you squeeze the pliers.You could
end up with a hand full of glass along
with a few cuts and a lot of your own
blood oozing all over your best work
shirt.
WINDY
To all those who think ..........................
  • 1 month later...
I've found using a rubber strap wrench useful in holding the container while I use a pliers on the cap. It doesn't seem to crush the can as a large pair of pliers does.
SkipJ
A guy from Louisianna once showed me to take glass jars and knock the lip of the lid on a hard surface (edge of driveway, brick wall...) it loosens up whatever's stuck and most lids'll come right off
Gilligan's Leather
Facebook.com/GilligansLeather
Sounds like wisdom bought with experience! :-)
shirt.
WINDY
IMHO, heat guns and paint jars are a no-no. :-)
Ed
To prevent them from sticking in the first place, I use Vaseline or petroleum jelly on the threads and I never have a problem. I doesn't evaporate and doesn't allow the glue to harden.
To remove a frozen cap. I use channel-locks. They adjust to a size that I don't have to put a lot of squeezing pressure on the cap to loosen it.
Marlon
Great answer!
:You_Rock_Emoticon:
Ride Safe!
Bree
2003 Dyna Wide Glide
Memberships:
Iron Butt Association, Niagara Falls HOG, Wild Fire HOG
NRA, Niagara County Sportsman's Association
