Members rmcninch108 Posted June 14, 2024 Members Report Posted June 14, 2024 I was wanting to know how to remove the scales on the flesh side of alligator tail so it will lay flat. I will post a couple of Pictures to show what I'm talking about, thanks in advance, Robert Quote
Members Norton Custom Leather Posted June 16, 2024 Members Report Posted June 16, 2024 I work with exocits on a regular, the armor plates can be removed tho it will leave holes. It is possible tho the time it would take would not be worth the effort. If you want smooth alligator/croc/camin I would recommend using the belly of them. if you just want to try you will have to cut around each armor plate & skin the hide. Much like skinning a deer or cow ect. for processing. Then you would have to lay the piece back flat & glue into place from the opposite side. If you are going to use the tail, that task is near impossible as you can not lay the raised tail section flat. No place to lay them. Quote
Members rmcninch108 Posted June 27, 2024 Author Members Report Posted June 27, 2024 Thanks for the advice! Quote
Northmount Posted June 27, 2024 Report Posted June 27, 2024 11 hours ago, rmcninch108 said: Thanks for the advice! Moved your post to "Exotics, Reptiles, Furs and others" Quote
