Members DaleksInc Posted August 8, 2024 Members Report Posted August 8, 2024 Per the title, I'm interested in using some (mid-sized) embossing plates, but don't have a clicker (and probably won't for a while; those things are somewhat expensive.) Is it possible to use an embossing plate without one, or am I out of luck? Quote For in Christ Jesus you are all sons of God, through faith. For as many of you as were baptized into Christ have put on Christ. There is neither Jew nor Greek, there is neither slave nor free, there is no male and female, for you are all one in Christ Jesus.
Contributing Member fredk Posted August 8, 2024 Contributing Member Report Posted August 8, 2024 (edited) I use a Tandy Pro press, others use arbour thingies, what ever can give pressure. I have number of different sized embossing plates I use And if the plate is not too big a ginormous whack with a mallet will do the trick too Edited August 8, 2024 by fredk Quote Al speling misteaks aer all mi own werk..
Members TonyV Posted August 8, 2024 Members Report Posted August 8, 2024 a desktop arbor press should work. or my ex could stand on it Quote
kgg Posted August 8, 2024 Report Posted August 8, 2024 28 minutes ago, DaleksInc said: but don't have a clicker (and probably won't for a while; those things are somewhat expensive.) Just to add to the list if you have a hydraulic shop press that would also work. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Contributing Member fredk Posted August 8, 2024 Contributing Member Report Posted August 8, 2024 . . . . a car, a hydraulic jack, the ground . . . . Quote Al speling misteaks aer all mi own werk..
toxo Posted August 9, 2024 Report Posted August 9, 2024 If nothing else, dampen the leather slightly and squeeze between couple of boards with some clamps will get you out of trouble. Quote
