The tension unit remained the same so it is the same on all 29 / 29K machines at least on the most common ones that I have seen.
More pictures you´ll find in the thread I have linked in the 3rd post above. I no longer have this 29K1.
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
This machine looking great I am fixing my 29k2 which is missing parts I have ordered most of the parts except the leaf spring and adjuster one of great member on here offered me the help and parts but I want to fix this machine cheap l am looking to make this spring by myself if I can get the measurements as well as the breaket measurements here are some pictures of my efforts.
Edited by richco
ok  you need the  spring and cup for the top tension unit, the long tension bar, thumb screw and nut, the clamp, washer and wing nut. that I can see.   You have the long bar i believe.    Also a foot, thread adjustment clamp, thumb screw and gib.
glenn
Thanks for reply, I don't have this long spring and the adjuster thinking to make my own simple enough to make if I can get the dimensions of the long leaf spring and adjuster pleas help.
           Thanks
I think I have the long bar assembly.  That is about $90.00 us.  hARD TO FIND.
GLENN
GLENN
Could you please send me measurements of it I can make it,just the spring steel and the adjuster is mild steel I do have milling machine and lathe to do the job I only need the dimensions please.
                        Thanks
ok   give me a day or so.
glenn
glenn
Thanks a lot .
will get measurement today for you.  Been crazy the last few days. I need to send you some pics.  You have an email?
glenn
glenn
Please check your PM box I have sent you my email.Thanks
