Members Sierra Posted August 13, 2024 Members Report Posted August 13, 2024 I was recently asked to repair some McClellan style saddles, from a saddle maker that is now retired, with the possibility of building more. Got the originals fixed up and sewed them back together by hand to hit all the same holes. My question is if anyone has had any luck with machine sewing around the bars on them or is hand sewing the only way to go? I was looking at a stirrup plate for the Adler as a way to get up close to the bar. I also had to fix the metal gigs on the front and back of the saddles but have not been able to source ones for new builds. I did pattern them while they were off though if there is someone that could build them. Quote
Members Dwight Posted August 14, 2024 Members Report Posted August 14, 2024 I had a beautiful old saddle brought to me to repair the sheep wool on it. It was just plain rotten . . . touching it at all with the least force and it came off in chunks. I took it all off . . . pulled out the old stitches (talking about a job) . . . then I cut new wool to go on it . . . glued it in place with weldwood contact cement . . . put the piece with the wool down . . . played with my Tippmann Boss machine . . . and was able to re-sew it using the original holes. Customer was a bit unhappy because he wanted it repaired . . . but came around when I explained it was the only way. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Northmount Posted August 15, 2024 Report Posted August 15, 2024 On 8/13/2024 at 9:36 AM, Sierra said: I was recently asked to repair some McClellan style saddles Why the double post? I moved your first (identical post) to Saddle construction. Please do not double post!! It breeds inconsistency, and people respond some to one, and others to the other. Kind of screws things up. I'm deleting your first post since no one has replied to it. Quote
Members Sierra Posted August 19, 2024 Author Members Report Posted August 19, 2024 On 8/14/2024 at 8:20 PM, Northmount said: Why the double post? I moved your first (identical post) to Saddle construction. Please do not double post!! It breeds inconsistency, and people respond some to one, and others to the other. Kind of screws things up. I'm deleting your first post since no one has replied to it. Didn't know you could move it, thought you were telling me it needed to be posted in a different section so I did. Quote
Northmount Posted August 19, 2024 Report Posted August 19, 2024 59 minutes ago, Sierra said: Didn't know you could move it, thought you were telling me it needed to be posted in a different section so I did. Funny how I said I "moved" your post that you would think that. Communication sure has its pitfalls. So many miscommunications cause so many problems. Quote
