Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 Thank you for the above. If you google any one of my products and I have many, you will find out that I do not sell them or market them anywhere. My intentions are to network with like minded people in the leather industry. What is your opinion on my leather punch? Do you find it an asset or a valuable tool for belt makers? Quote
kgg Posted August 22, 2024 Report Posted August 22, 2024 11 hours ago, BianVariani said: While I have not yet commercialized these tools, I am proud to share my knowledge and expertise with the public. 16 minutes ago, BianVariani said: What is your opinion on my leather punch? Do you find it an asset or a valuable tool for belt makers? I did like the video ( https://variani.com/videos/belt-punch-and-cutter-machine.mp4 ) you did post under another topic about the press. The quality of the setup seems to be quite nice. I think this style of guide could be adapted for use with a standard hand press or modified for the less expensive drill press guides. I did like the self centering feature but the distance between the holes could be better refined as some might like the holes closer together while others farther apart depending on the use of the belt / strap. A belt to hold up your pants verses a gun belt. I can see it being an asset but cost would be a major factor and it would be in competition with such items like pre made clicker press dies with the hole punches build in. I do have to agree that when I did read your post I did think of it as an advertisement as some others had I would suggest that you really need to write your post slightly different as not to give the impression of it being an advertisement. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 The belt hole distances I use are tailored to the belts I create. However, it's a valid suggestion to update the design to make the spring-loaded alignment bearing adjustable. The cutting plate, which incorporates this spring-loaded bearing, is interchangeable, allowing for different dies or cutting plates to be used as needed. The cutting plate itself functions as a die integrated into my manual hand press. Depending on the project, I use various custom-made dies and cutting plates designed specifically for the belts I produce. One of my concerns with die-based punches that rely on a clicker press is the limitation imposed by the fixed design of the die. If the die components are welded together, you're restricted to that specific design. I needed a tool that allowed flexibility, where I could easily swap out cutting and punching tools in my manual hand press, which led to the development of my design. My goal was to create a small, lightweight, and portable press/punch that is user-friendly and versatile enough to make belts on demand, whether I'm in a hotel room, at a trade show, or visiting a client. Clicker presses are often too heavy, bulky, and restrictive from a design standpoint. I wanted the freedom to create and adapt designs as needed, which my model allows. While I own a range of clicker presses, from manual to hydraulic, and even high-end machines capable of punching belts at high speeds, none offer the on-demand design flexibility that my portable press does. Quote
Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 (edited) Quote Please note that the self-centering guide is versatile and can be easily interchanged with other guides. For example, it can be replaced with guides designed for hot stamping, edge stitching, edge-painting, or precisely positioning holes in various offset locations. As I travel across the country and visit retail locations that carry my products, a common request from people I meet is whether I can make them a belt right now. In the past, I had to decline due to the lack of tools on hand. However, I have now bridged that gap, allowing me to say "Yes, absolutely!" This innovation has made my process more flexible and versatile, enabling me to meet customer requests wherever I am. Edited August 22, 2024 by BianVariani Quote
Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 Over the past 10 years, I created all kinds of prototypes. This design went nowhere aside from using it as educational. Quote
Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 This is another design that was used as a learning experience. Quote
Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 This is an update to practicing on building manual press punches. Quote
Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 more old designs Quote
Members BianVariani Posted August 22, 2024 Author Members Report Posted August 22, 2024 I use to use this manual Press for many years until I mastered my NEW design. Quote
Members Ddat Posted August 23, 2024 Members Report Posted August 23, 2024 Well, if you're showing off, keep going! Pretty cool stuff. But damn, lose the corporate speak. It's turning people off. Quote
