Members SoMoKraftworks Posted August 23, 2024 Members Report Posted August 23, 2024 (edited) I have always been curious how does one cut a strap from a hide that will need to be a length between 15'-30'? Given that most hides are about 8' in total length. What is the method of loop or spiral cutting for lack of a better term to make one consistent length longer than a standard leash. Keeping in mind this is out of 9-12 ounce latigo and strap width of about 1/2". Picture for reference. Edited August 23, 2024 by SoMoKraftworks Quote
Contributing Member fredk Posted August 23, 2024 Contributing Member Report Posted August 23, 2024 You cut a big circular spiral of the strap width in the best area of the hide, avoiding the belly. Then wet it thoroughly, stretch it out and let it dry and you have a strap as long as you want Quote
Members TonyV Posted August 23, 2024 Members Report Posted August 23, 2024 Fred has the answer. I cut and straighten lace that way, too. Bonus hint, pull the strap through a round hole while it's damp to make it round. Quote
Members SoMoKraftworks Posted August 23, 2024 Author Members Report Posted August 23, 2024 Kind of what I figured but with no videos anywhere I was just assuming. Thanks so much for the responses! Quote
Contributing Member fredk Posted August 23, 2024 Contributing Member Report Posted August 23, 2024 There is another way to cut the strip; cut along the backbone area the full length, at a curve, at the end do a gentle sweeping 180* turn-about and keep cutting, at the end you started at do another gentle sweeping 180* turn-about, keep cutting, repeat. Then thoroughly soak the leather, stretch out tightly and let it dry completely, then you have your very long strap Quote
Contributing Member fredk Posted August 24, 2024 Contributing Member Report Posted August 24, 2024 I just remembered, I think it was Tandy sold a spiral die cutter. I think it was for cutting long runs of lace Quote
Members TomE Posted August 24, 2024 Members Report Posted August 24, 2024 22 hours ago, SoMoKraftworks said: I have always been curious how does one cut a strap from a hide that will need to be a length between 15'-30'? Given that most hides are about 8' in total length. What is the method of loop or spiral cutting for lack of a better term to make one consistent length longer than a standard leash. Keeping in mind this is out of 9-12 ounce latigo and strap width of about 1/2". Picture for reference. It is standard practice to splice straps together for driving reins. Skive the ends for about 5-6 inches of overlap. Two or three lines of stitching down the length of the splice. Quote
Members Dwight Posted August 24, 2024 Members Report Posted August 24, 2024 And when you go to figure out how big a piece you will need . . . remember that if the strap were 1 inch wide . . . in one square foot . . . you would have 12 feet of 1 inch strap. Since you are cutting it at 1/2 inch . . . that doubles the strap length to 24 feet . . . if you want a 30 ft strap . . . you can start out with 1 1/4 square feet. Cutting it in a square piece is impossible so you at least have to look at a circle as the first possibility . . . and you don't want to have the last few inches sorely bent . . . Cutting an 18 inch circle . . . using a strap cutter set at 1/2 inch . . . you would wind up with a 30 ft strap . . . and roughly an 8 inch diameter piece left over in the middle. Again . . . soak it . . . stretch it . . . let it dry . . . viola . . . STRAP . . . May God bless, Dwight (provided I did my math correctly . . . ) Quote
