Members Gosut Posted September 21, 2024 Members Report Posted September 21, 2024 A slab for tooling, I understand. What, though, should I put under it to protect both the bottom surface and what I put it on? First thought: old towel. Second thought: cardboard. Third thought: Poundo board. The latter raises another question: Poundo board on top of slab to protect it when punching, i understand. I'm currently using old magazines and a plastic cutting board on a synthetic countertop surface, but wondering if the cutting board could mar the slab under impact. Quote
Members Littlef Posted September 21, 2024 Members Report Posted September 21, 2024 I have one of those green self healing mats I keep on my work surface. It just stays on the work surface 95% of the time. Then I just put the granite slab on that. Depending on what I’m doing and how much noise it’s making, I also have a 1/4” thick piece of that rubbery pondo board. Sometimes I put that under the granite slab to absorb some noise. if I’m punching holes I put a cutting board on top of the granite. You definitely don’t want a hole punch hitting the granite.. Sometimes I don’t even use the granite when punching holes. — unless I have a lot to punch. I primarily use the granite for stamping. If I’m setting rivets I actually have a little anvil. The steel anvil makes quick work of rivet setting, cause it’s designed to be struck. Good energy transference. Quote
Members DieselTech Posted September 21, 2024 Members Report Posted September 21, 2024 I see alot of these famous/well experienced leather guys put a cut up cereal box under their slab, lol most of the time it is a beer box thou. Some I have seen put a piece of upolstery leather under their slab. Like 1mm thick. Quote
Moderator bruce johnson Posted September 22, 2024 Moderator Report Posted September 22, 2024 On 9/21/2024 at 7:35 AM, DieselTech said: I see alot of these famous/well experienced leather guys put a cut up cereal box under their slab, lol most of the time it is a beer box thou. Some I have seen put a piece of upolstery leather under their slab. Like 1mm thick. You bet. Most of those old stamp rocks were not smooth or surfaced on the bottom. I was taught early on the put it on something besides a bare tabletop. One reason is to muffle sound but you don’t want something that absorbs a lot of the stamp force . One common suggestion is a sand bed. I had one bench I could do that with - worked great. I’ve also used poster board. My current rock is a granite inspection plate inlet into the bench. It sits on a matching size piece of 4 oz chrome tan leather underneath. It’ll never be pulled out but absorbs sound and stamp bounce. Quote
Members DieselTech Posted September 22, 2024 Members Report Posted September 22, 2024 17 minutes ago, bruce johnson said: You bet. Most of those old stamp rocks were not smooth or surfaced on the bottom. I was taught early on the put it on something besides a bare tabletop. One reason is to muffle sound but you don’t want something that absorbs a lot of the stamp force . One common suggestion is a sand bed. I had one bench I could that with - worked great. I’ve also used poster board. My current rock is a granite inspection plate inlet into the bench. It sits on a matching size piece of 4 oz chrome tan leather underneath. It’ll never be pulled out but absorbs sound and stamp bounce. Yeah I should have added that to my comment, that I put it under my slab to reduce noise. Guy will be amazed at how much it helps to tame the noise. Quote
