looks good so far - how ever some fine tuning could be necessary. Little hint - the thread should run above the thread lever and not under it.
  • Replies 49
  • Created
  • Last Reply
Top Posters In This Topic
Thank you for all the information and help. This is how it's currently sewing. The white thread is thinner than the brown but it's the only other thread that was a contrasting color to see if my tension was right.
looks good, hope you have fun with this machine and it suits your needs 😃
Edited by Constabulary
This thread has been quite the fun read, with good pics :thumbsup:
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
One quick last thing. I got the new needle bar to make the change so I can use larger needles but I realized that the one it already has on fits the same size needle and they have the same size opening. Seems like other than the length and age the needle bars are the same. I wonder if someone had already made the change.
The image shows the new needle bar I ordered and the current needle size that I'm using it fits seamlessly.
no one knows the history of this machine maybe one of the former owners had the same idea and change the NB some time ago. Who knows?
One of the joys of buying old(er) machines, you never know what may have been changed. :rolleyes2:
Calidora, looks like you've got it sorted and could be a handy machine to have.:specool:
Ok. So apparently this machine has seen heavy use. The take-up lever eyelet is getting close to being cut open by the thread. Is there a way to remedy this? Other than replacing it that is.
hard soldering then drill the hole and polish it but new take up levers are available new. Should be this one but check parts list first:
https://www.ebay.com/itm/196288462626
I´d buy a new one.
I´d buy a new one.
Thank you. I'll just buy one I should learn how to disassemble this machine anyway.
