Members redline Posted November 13, 2024 Members Report Posted November 13, 2024 Can chrome tanned leather be dyed or vinegarooned with minimum or no rub off afterwards? Quote
Contributing Member fredk Posted November 14, 2024 Contributing Member Report Posted November 14, 2024 It can be dyed, but I don't know about vinegroon as I don't use it If the chrome tan is pre-dyed, I use cellulose thinners as a prep. Then I dye it. Quote
Northmount Posted November 14, 2024 Report Posted November 14, 2024 21 hours ago, redline said: Can chrome tanned leather be dyed or vinegarooned with minimum or no rub off afterwards? If there isn't any tannin in the leather, vinegaroon won't work. Maybe soak it in tea first. Quote
Members SUP Posted November 15, 2024 Members Report Posted November 15, 2024 (edited) @Northmount I was wondering. As there is no tannin in the leather in the first place, the tannins from tea might remain on the surface and interact with vinegaroon but bleed because there is nothing to hold it to the leather. Of course, I might be wrong about. Edited November 15, 2024 by SUP Quote
Northmount Posted November 15, 2024 Report Posted November 15, 2024 12 minutes ago, SUP said: @Northmount I was wondering. As there is no tannin in the leather in the first place, the tannins from tea might remain on the surface and interact with vinegaroon but bleed because there is nothing to hold it to the leather. Of course, I might be wrong about. I've had leather jackets - chrome tan - soaked right through to my skin when I've been out in the rain for an hour or more. I think that the tea would be absorbed into the leather if allowed to soak. My back was dyed blue from my soaked black leather jacket. Took a few days and showers to get back to normal. Quote
Northmount Posted November 15, 2024 Report Posted November 15, 2024 On 11/13/2024 at 4:52 PM, redline said: Can chrome tanned leather be dyed or vinegarooned with minimum or no rub off afterwards? By the way, vinegaroon is not a dye, but a chemical reaction. It doesn't rub off. Quote
Members SUP Posted November 15, 2024 Members Report Posted November 15, 2024 8 hours ago, Northmount said: I've had leather jackets - chrome tan - soaked right through to my skin when I've been out in the rain for an hour or more. I think that the tea would be absorbed into the leather if allowed to soak. Even if the tea absorbs, will the tannins bind? Even after the iron acetates form, the color might bleed if damp or wet. I tried using tea once and that is what happened. Again, I might be wrong about this but my experience is that using tea and then vingaroon causes bleeding of the black color. Without the tea, it never bleeds because those tannins are bound to the leather, so there is nothing to bleed. Quote
Northmount Posted November 15, 2024 Report Posted November 15, 2024 3 hours ago, SUP said: Even if the tea absorbs, will the tannins bind? Even after the iron acetates form, the color might bleed if damp or wet. I tried using tea once and that is what happened. Again, I might be wrong about this but my experience is that using tea and then vingaroon causes bleeding of the black color. Without the tea, it never bleeds because those tannins are bound to the leather, so there is nothing to bleed. As with most leather dyes, paints, finishes, etc. Do test pieces to verify what works for your leather and circumstances. Quote
