bnsmith Report post Posted 4 hours ago I recently acquired a walking step 111W156, so newbie here. With the machine I received two sets off needles (pictured). Can the 111W156 accept both systems (135 X 17 or 134 - 35) with no adjustment ( as from what I can tell there is a ~.9mm difference in length according to spec). Is there a reason to want to use the 134 system, or would another 135 type work just as well? Thanks Brian Quote Share this post Link to post Share on other sites
Northmount Report post Posted 4 hours ago 14 minutes ago, bnsmith said: Is there a reason to want to use the 134 system, or would another 135 type work just as well? The 134-35 LR appears to be a leather needle. This needle system was made for PFAFF. You can use the 135-16 leather point instead. Your choice maybe determined by availability and cost. Since he supplied both, appears the machine is happy with either, that's my guess. Quote Share this post Link to post Share on other sites
Constabulary Report post Posted 4 hours ago (edited) the 135x16 / 135x17 is slightly longer than 134-35. Depending on how the machine is adjusted it is possible that both needle systems work w/o changing the needle bar height. But I´d recommend the 135x16 / 135x17 needle. Check the manual for the needle bar height and needle Hook timing and set is up as recommend for 135x17 / 135x16 - thats what I would do. The difference is 0.8mm - see pictures. Edited 4 hours ago by Constabulary Quote Share this post Link to post Share on other sites
kgg Report post Posted 4 hours ago 32 minutes ago, bnsmith said: With the machine I received two sets off needles (pictured). The correct needle system for the Singer 111W156 is 135 x 16 for leather and 135 x 17 for fabric. The person might have owned a PFAFF machine or purchased them incorrectly or converted the machine to use needle system 134. I would pull the needle in the machine and see what is actually in the needle bar. Like @Constabulary check the needle bar height and use needle system 135 x16 or 135 x 17. kgg Quote Share this post Link to post Share on other sites
bnsmith Report post Posted 2 hours ago @Constabulary Thanks for the pics! I have not seen those particular ones before. Could you give the link? Is there one for 135X16? What does the pale blue diagram indicate? I get R and L as Right and Left but what does C and P mean? All Very hard to tell these needles apart, would the R and LR be easier to spot the difference? Any ideas on the tolerances + - on setting the needle bar height? .8 mm is not a lot. Does the bobbin hook pass the centre off the needle cutout? Finally what size thread is used with these needles, and would there be a source of samples of thread sizes? I don't have a good mental picture of what the sizes look like in leather yet (my ultimate goal) Thanks Brian Quote Share this post Link to post Share on other sites
