ljk Posted November 27, 2024 Report Posted November 27, 2024 I've had 2 of those, one my first upholstery machine and 30 years later picked up at a auction for a few bucks. I used on the bike circuit, was great because I could see very well what I was doing. Here's what I did. Bought a narrow Teflon foot, got a narrow feed dog to match, set tension moderately. Good machine until you can afford a 206rb. Quote
Members Lugubrious Posted November 27, 2024 Author Members Report Posted November 27, 2024 3 minutes ago, ljk said: I've had 2 of those, one my first upholstery machine and 30 years later picked up at an auction for a few bucks. I used on the bike circuit, was great because I could see very well what I was doing. Here's what I did. Bought a narrow Teflon foot, got a narrow feed dog to match, set tension moderately. Good machine until you can afford a 206rb. It’s a great machine, if I could figure out the stitch length issue it’ll be my golden goose! 5 hours ago, CowboyBob said: Ok,if they both are all the way in try raising the feed dog so it can lift the leather off the plate,also check that feed dog doesn't have any play in it by pushing it front to back,try the needlebar too,sometimes parts in the feed system get loose & need to be tightened or replaced. Would those things get in the way of the stitch length adjustment? Quote
Members Constabulary Posted November 27, 2024 Members Report Posted November 27, 2024 10 hours ago, Lugubrious said: So I do have the set screw and spring, I’m confused where you speak of the spindle I hope this photo is the the spindle. I can see some threads on the tip but it looks pretty flat. I’ve heard of people grabbing a dremel using that to get the spindle right. I’m just not sure if I’d be sanding it down Yes that is the spindle. But don´t mess the tip with a Dremel. What you see on the tip are traces of part # 13066 that pushes against the tip when changing the stitch length. Not sure if you got me right. There is a short coarse thread on the end of the top shaft (red circle) and there is a small pin inside the knob of the spindle (red arrow). And this little pin has to follow the thread when you turn the knob for changing the stitch length. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Lugubrious Posted November 27, 2024 Author Members Report Posted November 27, 2024 14 hours ago, Constabulary said: Yes that is the spindle. But don´t mess the tip with a Dremel. What you see on the tip are traces of part # 13066 that pushes against the tip when changing the stitch length. Not sure if you got me right. There is a short coarse thread on the end of the top shaft (red circle) and there is a small pin inside the knob of the spindle (red arrow). And this little pin has to follow the thread when you turn the knob for changing the stitch length. Looks like a broken pin to me, the threads at the end of the top shaft look good. So this pin must be the culprit. Looks like a tedious piece to replace. Would you just recommend replacing the whole knob itself? Quote
Members Constabulary Posted November 27, 2024 Members Report Posted November 27, 2024 The broken pin is the problem as it seems. I´m not sure if you can replace the pin, the knob may be hardened. And I do not know if the spindles are still available. I have one but I´m in Germany and it is from a Singer 111 machine not sure if the stitch numbers are the same. Anyway, I would check with Bob Kovar from Toledo Sewing Machines. He replied in this thread as CowboyBob (see above). He may have some old stock parts. If he has none we maybe can talk. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Lugubrious Posted November 28, 2024 Author Members Report Posted November 28, 2024 4 hours ago, Constabulary said: The broken pin is the problem as it seems. I´m not sure if you can replace the pin, the knob may be hardened. And I do not know if the spindles are still available. I have one but I´m in Germany and it is from a Singer 111 machine not sure if the stitch numbers are the same. Anyway, I would check with Bob Kovar from Toledo Sewing Machines. He replied in this thread as CowboyBob (see above). He may have some old stock parts. If he has none we maybe can talk. Okay cool! I’ll shoot him a message. Hopefully I can figure this out. I’m okay with the stitch setting it has right now but would like to get longer stitches for decorative stitching. Will shoot Bob a message thank you for clearing all of this up for me and narrowing down the issue. Quote
Members Constabulary Posted November 29, 2024 Members Report Posted November 29, 2024 Please let us know if and how your problem got solved. Always good to have a feedback just in case someone else will have a similar problem. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Lugubrious Posted December 5, 2024 Author Members Report Posted December 5, 2024 On 11/29/2024 at 11:04 AM, Constabulary said: Please let us know if and how your problem got solved. Always good to have a feedback just in case someone else will have a similar problem. Haven’t figured it out yet Quote
Members Constabulary Posted December 5, 2024 Members Report Posted December 5, 2024 just yesterday I looked at the spindle on my Singer 108w and it looked like the pin is replaceable. I cross checked another 153w pats list and pound the pin as spare. Parts # is 202443 And I found it online: https://parts.jacksew.com/pin-generic-202443/ Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted December 9, 2024 Members Report Posted December 9, 2024 I would drill the pin out and replace it with a roll pin cut to length the roll pins are hardened. glenn Quote
