Northmount Posted November 1, 2025 Report Posted November 1, 2025 @AndreaIbis You should be posting using English. It is the language for this site. You have included English before so I guess it slipped your mind with these posts. Quote
Members nylonRigging Posted November 2, 2025 Members Report Posted November 2, 2025 8 hours ago, AndreaIbis said: Only the maximum zigzag stitch length of 9–10 mm isn't as expected (instead of 12 mm). Perhaps something needs adjusting, but I can't figure it out at the moment. Was thinking you might check the Needle scarf size ? , Shorter length Scarf limits Hook travel, and some needle manufactures have longer length Scarf . Longer Scarf, the Hook will be able to move past the top and bottom of Scarf in little wider path on each needle stroke . Wider Scarf also lets you get more ZZ width without tapping top and bottom of the Scarf with the Hook, and help stop Hook wear. - - Quote
