Members equineequus Posted December 1, 2024 Members Report Posted December 1, 2024 Hi all, Thanks to all you industrial sewing machine posters for all the advice I've benefited from. This is my 2nd post....because I am absolutely stumped and no amount of searching has helped me figure out what the heck happened. I'll give you the simple facts first- I'm using 138 thread, #22 needle, sewing leather usually, within thickness range of 3/8 inch, machine sews well, with the occasional tweaking of tension for some seams. It's a KOBE LS 1341, looks just like TECHSEW 2750, Juki LS 1341. Problem: I sewed a rip in a horse blanket recently. That involved the thickness of the blanket plus webbing folded over the fabric edge. The total thickness may have exceeded the 3/8 inch the machine is speced for, but not by much. The machine sewed the horse blanket seam ok. A bit of top thread tension tweaking was required but I got the job done. I was cleaning the bobbin area afterwards with compressed air, (the blanket was pretty dusty), pulled the bobbin, then returned it, making sure I got all the dust out. Once cleaned, I turned the handwheel and it was stuck, wouldn't turn. Nothing had been changed since sewing, other than cleaning. I checked the bobbin, pulled thread from bobbin and pulled thread through needle just to make sure it wasn't a source of snag. No issues with resistance. Pulled the throat plate and bobbin case to check for thread debris . Found nothing. Checked the handwheel, and it turned freely......odd. So while putting the throat plate back on I noticed that onced I tightened the throat plate screws, the hand wheel was stuck again. I reloosened the throat plate screws and again the hand wheel turned. Retightening the throat plate screws I checked the feed dog clearance and the tighter I made those screws the less clearance there was between the inner side (right side) of the feed dog and the hole in the throat plate. The feed dog was not bent, nothing was visibly loose.....I couldn't find anything to explain why the feed dog now touched the throat plate. Stumped. Please help..... Quote
Members DieselTech Posted December 1, 2024 Members Report Posted December 1, 2024 I was told every time you have the throat plate off. You got to adjust it so the feed dog don't contact the sides of the throat plate. I think you just need to readjust your throat plate. Also leave the throat plate a touch loose & cycle your machine by hand to help align it. Then hold the throat plate as you snug the screws. Quote
Members equineequus Posted December 2, 2024 Author Members Report Posted December 2, 2024 (edited) Thanks DieselTech, I'll give that a try. I was gonna leave the screws looser as a way to fix this issues simply because I couldn't figure any other resolution. It's a strange thing just the same....appreciate your feedback Edited December 2, 2024 by equineequus Quote
kgg Posted December 2, 2024 Report Posted December 2, 2024 5 hours ago, equineequus said: I'll give you the simple facts first- I'm using 138 thread, #22 needle, sewing leather usually, within thickness range of 3/8 inch, machine sews well, with the occasional tweaking of tension for some seams. It's a KOBE LS 1341, looks just like TECHSEW 2750, Juki LS 1341. Yes the Kobe LS-1341 is the same as Techsew 2750 and both are a clone of the older Juki LS-341 not the Juki LS-1341. I have owned a Kobe LS-1341 and presently have a Techsew 2750 Pro both are the same. A good manual to down load would be the engineering manual for the Juki LS-341. From my experience with the Kobe LS-1341 the #22 needle is really meant to be used with V92 in thick or tough or sticky materials. When using V138 thread I would go with a #23 and when sewing at or close too the machines max probably go up to #24. Here is a good thread to needle size chart: https://www.tolindsewmach.com/thread-chart.html kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members equineequus Posted December 2, 2024 Author Members Report Posted December 2, 2024 14 hours ago, kgg said: Yes the Kobe LS-1341 is the same as Techsew 2750 and both are a clone of the older Juki LS-341 not the Juki LS-1341. I have owned a Kobe LS-1341 and presently have a Techsew 2750 Pro both are the same. A good manual to down load would be the engineering manual for the Juki LS-341. From my experience with the Kobe LS-1341 the #22 needle is really meant to be used with V92 in thick or tough or sticky materials. When using V138 thread I would go with a #23 and when sewing at or close too the machines max probably go up to #24. Here is a good thread to needle size chart: https://www.tolindsewmach.com/thread-chart.html kgg Thanks @kgg. I'm awaiting #23 needles delivery. And thanks for the engineering manual suggestion. Quote
Members Wyowally Posted December 3, 2024 Members Report Posted December 3, 2024 After some experience with filthy horse blankets, I charge almost double if they aren't clean. The cleaning after takes more time than the repair, and that filth goes everywhere. Quote
