Looks like a home-made edge burnisher to me.
https://www.campbell-randall.com/product/model-vsb-burnishing-machine
I've had one for a few years and it's a great edge burnisher.
Well, there you go. The one in the OP's photo is certainly a bit the worse for wear (hence my home-made comment).
When I purchased my vsb burnishing machine there were several wood/felt/diamond coated "plates" available.  The motor has a variable speed dial and there is a switch to reverse the rotation direction.
The vsb also has an attachment that fits over the "plates" to attached a vacuum too.  This attachment appears to be removed in the picture.
It is possible to stack two "plates" on top of the machine.  In the picture there is a wood "plate" over a felt & leather "plate".
The felt and wood "plate" comes new with a flat edge.  With use the felt "plate" will develop a natural groove for your belts, etc. to fit in.
The wood "plate" comes with a flat edge also and if you have woodworking tools you can sand or use a rat tail woodworking file to create a groove.
The diamond coated "plates" are already grooved and ready for use.
The machine is very quiet and has a small foot print.
Expand
Thanks so much.
I am planning to use a bench grinder and put a groove in it if possible for sanding the edges. What do you think ?
In my opinion the best path forward would be to find someone with a wood lathe to cut in a groove for you (I used my wood lathe to do this and it was fairly straight forward).
You'll be disappointed using a bench grinder to put in the groove - it will be "V" shaped and not a straight cut.
You could also draw a center line around the "plate" and place it in a vise and use a round 'rat tail' wood rasp to remove a "U" shaped groove along the face of the "plate".  You'll have more control
going this route than with a bench grinder.
I don't know the exact model of the burnisher in your photo, but the wheel is made by Galli in Italy. Look up Galli SPA on Google.
I have a Randall/Campbell VSB and Galli FCE/FCE+2 burnishers and they use the same wheels.  Randall/Campbell VSB's use Galli wheels as well.
You can buy a VSB from Randall/Campbell or make your own burnisher if you're handy. But, you'd need to either order the arbor for the wheel from Randall/Campbell or machine your own.  The cover plate that JD Bodger mentioned for the VSB is actually a Bosch made clear plastic cover for a router table.
Randall/Campbell builds the VSB on variable speed servo sewing machine motors, but you can use about anything you desire.   I'd strongly recommend just buying one from Randall/Campbell so you can get to work.
Edited by Cumberland Highpower
Expand
Since it appears the plan is to make a way to mount the disk (plate) and spin it to burnish the edges; why not mount it, spin it under power and hold the round file against it to make the groove?
Unless I'm misunderstanding what's going on here.
Edited by AlZilla
- Voltaire
- Aristotle
I agree with Cumberland. Purchase the machine from Randall-Campbell instead of trying to build one.  I've been there, done that thinking I could home build a machine better/cheaper than purchasing one and end up spending more money and being frustrated with the final product.
I don't recommend holding the rat tail file against the "plate" with your hands due to safety reasons.  The file handles taper to a dull point that could pierce a hand/finger/eye if the file were to catch on the spinning "plate".
