Members themig29 Posted December 15, 2024 Members Report Posted December 15, 2024 (edited) Did my first dip dying of some wallets I'm piecing together. All I've read is that the dye may bleed out with regular use. I'm looking at both resolene and carnauba wax to seal the projects. Any help on how these would work. And would a resolene application prevent the leather from developing a patina? Thanks! Edited December 15, 2024 by themig29 spelling Quote
Members DieselTech Posted December 15, 2024 Members Report Posted December 15, 2024 I don't think the resolene will cause it not to patina. It should still get patina with age/ wear. Maybe I'm wrong. I am sure others will chime in on this. Quote
Members themig29 Posted December 15, 2024 Author Members Report Posted December 15, 2024 Th 45 minutes ago, DieselTech said: I don't think the resolene will cause it not to patina. It should still get patina with age/ wear. Maybe I'm wrong. I am sure others will chime in on this. Thanks, I've seen some mixed messages on the internet about it. Would carnauba wax act as a good enough seal to prevent any dye bleeding? Since they are wallets, I'm not super concerned about them being waterproofed as exposure should be fairly minimal. Quote
Members DieselTech Posted December 15, 2024 Members Report Posted December 15, 2024 32 minutes ago, themig29 said: Th Thanks, I've seen some mixed messages on the internet about it. Would carnauba wax act as a good enough seal to prevent any dye bleeding? Since they are wallets, I'm not super concerned about them being waterproofed as exposure should be fairly minimal. I have not used carnuba wax. I do not think carnauba wax will seal leather from dye bleed out/ rub off. I use either Satin Shene or Super Shene from Tandy & it seems to do a good job for me. I personally think carnauba wax might make dye rub off/bleed out even worse. Quote
Members Dwight Posted December 15, 2024 Members Report Posted December 15, 2024 (edited) 8 hours ago, DieselTech said: I don't think the resolene will cause it not to patina. It should still get patina with age/ wear. Maybe I'm wrong. I am sure others will chime in on this. He's got this one right . . . at least that has been my 20+ year experience . . . There is no wax that will prevent dye rub off. A 50/50 application of Resolene and water will do the job though. And I've never figured out how it does it . . . but if you notice on your leather . . . there are lighter and darker spots . . . you would not have gotten so much of that had you given the leather a light coating of neatsfoot oil . . . but again . . . not sure how resolene does it . . . but it also smoothes out some of that. Make sure you post some finish shots of it/them before you send em up, up, and away. May God bless, Dwight Edited December 15, 2024 by Dwight Quote
Members themig29 Posted December 16, 2024 Author Members Report Posted December 16, 2024 14 hours ago, Dwight said: but if you notice on your leather . . . there are lighter and darker spots . . . you would not have gotten so much of that had you given the leather a light coating of neatsfoot oil . . . but again . . . not sure how resolene does it . . . but it also smoothes out some of that. Make sure you post some finish shots of it/them before you send em up, up, and away I cased with a spray/mister bottle before the dip and I'm guessing that the application was uneven. which resulted in the darker spots. I'd read that nearfoot should be applied after but you would recommend prior to? Should be getting to stich-up tonight or tomorrow so I'll post when done. Quote
Members Dwight Posted December 16, 2024 Members Report Posted December 16, 2024 (edited) 1 hour ago, themig29 said: I cased with a spray/mister bottle before the dip and I'm guessing that the application was uneven. which resulted in the darker spots. I'd read that nearfoot should be applied after but you would recommend prior to? Should be getting to stich-up tonight or tomorrow so I'll post when done. Neatsfoot oil before dying generally has given me a smoother . . . more even color . . . especially with Saddle Tan. Oiling afterwards just gives the leather a bit more softness and pliability . . . at least that has been my overall experience in 20 years. Wet leather has always given me bad dye resullts . . . I know others don't have that opinion . . . but that has been my experience. I case for stamping . . . nothing else. May God bless, Dwight Edited December 16, 2024 by Dwight Quote
Members themig29 Posted January 14 Author Members Report Posted January 14 On 12/15/2024 at 4:52 PM, Dwight said: Make sure you post some finish shots of it/them before you send em up, up, and away. Holidays got pretty busy, but here are two finished items. Next dip dye I plan on either dip casing, or not casing at all, to see if the dye is a bit more uniform. Overall, it still looks fairly decent with a bit of character. The one I gave to my brother has really patina'd well and that has helped the color too. Used carnauba finish and have had no issues with the dye bleeding onto anything else. Quote
