Members Pinto Posted December 18, 2024 Members Report Posted December 18, 2024 I was able to get about 200 single cap conchos for almost nothing. The problem is they did not have the caps. Does anoyone know if you can buy just the caps from somwhere? Thanks GUys/Gals Quote
Members DieselTech Posted December 18, 2024 Members Report Posted December 18, 2024 Can you post a pic of the conchos front & back. It will help the others help identify of what is needed & where to get them possibly. Thanks. Quote
Members Pinto Posted December 18, 2024 Author Members Report Posted December 18, 2024 this is what they look like Quote
Members Pinto Posted December 18, 2024 Author Members Report Posted December 18, 2024 this is what the front and back look like Quote
kgg Posted December 18, 2024 Report Posted December 18, 2024 On 12/18/2024 at 12:58 PM, Pinto said: this is what the front and back look like Expand I have never install one myself so I just watch a video of installing conchos ( https://www.youtube.com/watch?v=NL-eW6DkCEk ). I am going to assume your concho's stem is also threaded so it is just a matter of finding the correct size screw for attachment. I would use a nut / screw thread gauge to determine the size needed. For the most common sizes I find the Chinese nut / screw gauge similar to ( https://www.aliexpress.com/item/1005007315188557.html?spm=a2g0o.productlist.main.21.79e3ZdnIZdnIxM&algo_pvid=1aca4878-402f-4f94-9b21-d996454393f2&algo_exp_id=1aca4878-402f-4f94-9b21-d996454393f2-10&pdp_npi=4%40dis!CAD!23.62!12.99!!!16.13!8.87!%402103244817345326557723276e6b56!12000040228337903!sea!CA!3463193163!X&curPageLogUid=8y7oEuQnLAr1&utparam-url=scene%3Asearch|query_from%3A ) are good enough. If the conchos were made in the US then you will probably be looking at Imperial sizes. If they were made elsewhere chances are you are looking at metric sizes. From the photo it looks like a screw in the 3mil range which is about 1/8" would work.If you don't have a thread gauge take a concho to some hardware store as most have a gauge by the nuts and bolt display. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members DieselTech Posted December 18, 2024 Members Report Posted December 18, 2024 On 12/18/2024 at 12:55 PM, Pinto said: this is what they look like Expand Thanks. I think that style of concho uses a washer on the back that fits the hollow stud/tube. Then you use a a hollow tube rivet setter. Quote
Members DieselTech Posted December 18, 2024 Members Report Posted December 18, 2024 Maybe @bruce johnson is familiar with this style of concho & knows what tools it takes to set them. Hopefully he can set us straight on this. Quote
Members DieselTech Posted December 18, 2024 Members Report Posted December 18, 2024 Look at tubular rivet setter. I think that is what tool might be used/needed to set that type of concho. Quote
AlZilla Posted December 18, 2024 Report Posted December 18, 2024 Maybe you could find a tap and thread them. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members TomE Posted December 18, 2024 Members Report Posted December 18, 2024 That looks like a base for a Chicago screw. Chicago screws are typically 1/8" diameter machine screws (not sure about the thread pitch) and readily available. Use thread locker or nail polish on the threads to secure it. Quote
