  • CFM
Goal was to quite cutting so deep with the swivel knife, work on bargrounding and keep the background areas as small as possible. Second picture is on some Brazilian import from Frogjelly Leather. Lacks a little color but tools nice.
  • CFM
i love your knife cuts in the petals they are almost perfect. do you ever use lifters or how much do you if you do?
  • CFM
Yes have a whole set of Barry king but I use Crartool Pro series. I like they way they work better.
  • CFM
I made my own lol, but i see you do it much lighter than i do, it looks nice your way and won't smoosh down as easy i bet.
I am currently focusing on these as well (among others). My background areas always seem to grow. Your work looks great. Especially the decorative cuts as noted.
Randy
All I can really say is WOW!!
  • CFM
Thanks for the kind words. Correction, the top picture is the Brazilian import, the bottom is Herman Oak.
 Also working on tracing OUTSIDE the lines when tracing the pattern on to the leather.
  • CFM
I use a very thin Leatherwrangler blade for those decorative cuts. That thin blade is  .028 thick. Standard thickness is .125. The middle one is .042 thick. I cut all the pattern with it.
  • CFM
You can see the tracing lines in blue ink. Top one pretty much traced the pattern and the background gets bigger.
The bottom one looks much better and you can see how outside the lines I was tracing.
