It seem this Mil-T-5038H class 1A type lll has some very basic selection of colors.  Have a good source for a good burnt orange or tan brown?
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
These guys don't say their tape is 5038 but they have a lot of colors.   Does anyone know anything about this company?
https://americanplastics.com/collections/narrow-binding-tape
I bought some black tape that said it was 5038 spec tape on Amazon but the tape itself does not have that marked on it.  I suspect it is Chinese tape but it worked well in my binder.
An update on my binder:
I bought some 5038 tape off of Amazon.  It says mil spec but the tape is not marked as such.   Still, it works well in my binder.   Its quite slippery so it glides through the folder very nicely.
300 yards of black 1" was $35.00
https://www.amazon.com/dp/B0BPK36VBK?ref=ppx_yo2ov_dt_b_fed_asin_title
I also obtained some Sailrite bias binding, 1" black polyester.
https://www.sailrite.com/Top-Notch-9-Polyester-Bias-Binding-Tape-Black-1-Inch
This also worked well and it laid down a bit better than the 5038 in the curves.
The problem with the Sailrite tape is cost.  $136 for 100 yards, vs the Amazon 5038 tape which was $35 for 100 yards.
For my needs, which does not require showcase quality, the 5038 is very adequate.   I think if I used a more narrow 5038 tape I could get better results around the corners.  However, this is with my existing fixed binder.
I did order a synchronized binder off Ebay.  It should be here in about 3 weeks.  Apparently it is shipping from China.  They had the same items on Amazon and those also shipped from China.  It costs $130 including the bracket, feet, dog, and needle plate and folder.
Thanks for the help guys!  I really appreciate it!
Here are some picts:
Edited by Dave9111
Nice.. you are starting to work some binding, and working on building technique with laying down some stitches. the more you run binding, the easier it going to get for you, especially learning the little Idiosyncrasies your machine does with stitching and feeding it.
What you aying on that 'thinner' material you taping , and you using single-needle. If you turn radius with 3/4"width grosgrain typelll 1a, Instead of 1" wide . You are correct. The 3/4" will lay and turn nicer with less wrinkle distortion . Same for that Bias 1" the weave with single-needle. Bias always turns substantially tighter than the Grosgrain weave will . If you go 3/4" on that Bias, It will do some real tight turns and lay flat smooth/nice .
But.. you are getting the synchronized swing set-up and eventually working. So you will be able to just swap-out different size throats for taping width changes.
Dude.. 136-$ for 100 yrd. roll of 1" polyester bias is pretty SICK . I cant believe that price is correct ? . I pay usually in the .32 to .34 per yard for 100 yrd. mil.spec 1" Nylon 4082-1 herringbone-bias . The price for the Grosgrain is little high, but 'is what is' if you just picking up a roll or two occasionally off the Amazon .
I bought the folder head for 3/4" tape after your comment.  It was about $11 with shipping.  Crazy cheap!
I'll start looking for some 3/4" tape as well.
Its refreshing to have something that looks half way decent as a result!  I'm hoping the new binder can get results similar to what you are doing.   But there is some substantial skill involved which I still need to learn!
I fought with my old 100 yard roll of Rochford straight cut binding tape for years.
This 5038 tape that I bought off Amazon is like night and day compared to the crappy Rochford tape.   Its an entirely different game with the better tapes.
When I bought the bias binding tape at Sailrite, I only bought 10 feet of it and that cost about $7.00.   Just enough to figure out if it would work or not.  I think most Sailrite buyers are hobby folks making a few pieces of canvas for their boat or project and that's about it.   Their fabric prices are not low.   I could not afford to do what I am doing if I had to pay Sailrite prices for everything.    I buy most of my fabric off Ebay.  Some of it has minor defects, but since it is for me, I can deal with that for the lower prices.
When you buy binding tape, are you ordering it 100 yards at a time or a lot more than that?   32 to 34 cents per yard seems like a good price for real milspec tape.
What is a good price for 3/4" 5038 grosgrain if I am buying 100 yards at a time?
Does the 4082 herringbone tape lay down better in the curves than the 5038?
How do you determine when to use the 4082 vs the 5038?
Thanks!
Taking a harder look at that sailrite offering on that bias binding, It 'probably ?'  is quality weave for outdoors/marine environment, Poly for better UV life . it's double fold edge, so that is extra cost for them from the Mill. but the asking retail is pretty high-$ .
Buying off the Ebay is hit and miss,and lot of middle-man reselling. but I have run across some deals though in the past.
Ya if you buying 1 roll at time on-line off ebay/amazon then you are kind of stuck. when I buy binding and tape, I always buy no less than1-k yrd. @ a time, and that is really not that much tape, as I goes pretty quick. On a color I use all time, I have had done custom color orders with 5-k yrd. and that will last me about 3 years average. and when ordering from a mill, you really don't even begin getting any price cuts unless you start getting 10-k plus+  Yrd. . Good mil.spec.Nylon 3/4" typelll runs ( I paid ) anywhere from .22 to .26 yrd. it all depends if you ordering from a Mill, or getting from a supplier with them having order drop-shipped from a mill.
Ya herringbone-bias nylon lays down, turns and tracks good . Bias weave always flex's better than the straight line weave of grosgrain.
Financially...LOL,  you might want to move away from that sailrite Bias binding .   ( PM sent to you ) .
The grosgrain and bias look different, turn different . ( me ) i determine which, by the needs of the Item. ( i think ) Nylon Gross grain makes a visually nice presentation for finished edge trim like small items, pocket front edges..etc.. The herringbone-bias I use for heavy thicker outside seams of bags, or bigger items. It all personal preferences.
  • 3 weeks later...
I got out my other Pfaff 1245 to set it up for binding.  I fitted a servo motor to it for better control and tried to attach the feet, dog, and needle plate that came with the new synchronized binder.
The needle plate wasnt quite right but I had another needle plate that came with the original right angle binder I bought 10 years ago or so and that worked.  I had to grind the front foot so it didnt hit the left toe of the rear foot.  Also the new feed dog was a bit off to one side and it has a small needle hole so I had to move the feed dog mechanism to the right slightly to keep the needle from bending.  Whew!   A fair amount of work to get everything right.
The synchronized swing binder works nicely with milspec 5038 and 4088 herringbone binding tape.  The 1" 4088 can do a 1 inch radius with this binder setup.  Very nice.
Remember that I had bought some cheap polyester garment binding from Wawak and Amazon and that did not work in my original fixed right angle binder setup, well it doesn't work in the synchronized swing binder ether.  So thats consistent.
At this point I had many hours into trying to get this right.
I bought a $20 straight binder off of Amazon and thought I would try it as well.
I got it positioned and ran some milspec 5038 1" through it.  It worked ok if I didnt make too sharp a turn.  Same with the milspec 4088.  But the synchronized binder is easier to use.
Then I tried out the cheap garment quality Polyester binding with the straight binder.
It works!  So now at least I can use the 150+ yards of cheap polyester binder I bought.
Regarding the platter to feed the binding, I drilled another hole for the wooden machine rest pin on the back of the table and I'm using the pin and table to hold the flat reel of binding.  So far, so good.  Ill add pictures tomorrow.
Anyway, I think Im set.  Thanks for all of the suggestions.
Here are some pictures.
The pictures with the straight binder are using some of the thin garment polyester tape I bought off Wawak and Amazon.   One was a single fold polyester which just is a flat strip with both edges folded towards the center.   The other has, I believe, four layers of polyester folded over.  Both work fine with the straight binder but wont work at all in the synchronized binder.   The very thin polyester just cant maintain its shape as it goes through the right angle binder.  It rolls around and unfolds in the right angle binder head.  I would only use the thin polyester binding to hide raw edges that were not subject to much abrasion.   The milspec 5038 and 4088 tapes are much heavier and more durable.  That said, the thin polyester looks pretty good and would be ok for some uses.
Cost wise the milspec tapes are about the same cost as the cheap garment tapes which really doesn't make much sense.  The Wawak single fold polyester tape was about $36 for a hundred yards as was the Amazon multifold tape.  Milspec tape seems to be not much more expensive.
I'll probably stick to the milspec tapes for my uses which is mostly covers and some bags.
If you guys see anything I could be doing better.  Please comment.
Thanks.
Edited by Dave9111
I wouldn't comment on the 90 degree binder as I generally don't use them but I do have a couple suggestions when using the inline binders.
i) get a proper platter that the coil of binding tape would sit on so the tape is not being dragged on the table top.
ii) set the binding tape platter up so:
  a) the platter is off the table top and can spin freely.
  b) the tape is coming off the platter pretty close too but not rubbing the inside edge of the machine. Which also means you will probably have to install a tape guide between the platter and the binder that can give adjustable back tension.
  c) the platter and the binding tape needs to be high enough off the table top so the binding tape enters the binder at the right height and angle.
iii) The front edge where the tape exits can be slightly widened or closed with a pair pliers to add tension or make adjust for thinner or thicker binding tape. This can also be done on the end that the binding tape enters the binder.
iv) When finishing a run and you are overlapping the binding tape where you started from cut you binding tape and tuck it into the binder. That way you get a nice finished edge rather then a raw edge finish.
kgg
Edited by kgg
Thanks kgg,
I appreciate all the comments.   I have a binding platter on the way.
In the picture, is that a 335 or 246 style cylinder bed machine?
For bags and backpacks, I can see the desire of a cylinder bed machine.  Is there an advantage when using it with mostly flatwork as well?
Thanks, Dave
