kgg Posted March 17 Report Posted March 17 1 hour ago, Dave9111 said: In the picture, is that a 335 or 246 style cylinder bed machine? That is a very early mini table top attachment on a Kobe LS-1341 which in reality is a Juki LS-341 clone like the Techsew 2750. I have various setups of small table top attachments. Depends on what I am binding on which machine and how much tape I need. Photo 1 shows a platter, tape guide and a micro binder nose attachment on a Kobe LS-1341 Photo 2 shows is a better view of the micro binder nose attachment Photo 3 shows a mini table top attachment on Techsew 2750 Pro with a multi purpose tape guide / tape dispenser / tape tensioner. Photo 4 shows a mini table top attachment on Class 441 clone that has width guides on the table top and a multi purpose tape guide / tape dispenser / tape tensioner. 2 hours ago, Dave9111 said: Is there an advantage when using it with mostly flatwork as well? If it is flatwork the flatbed machines are a better choice most times. I was probably just lazy and didn't want to setup a flatbed machine to do one item. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Dave9111 Posted March 18 Author Members Report Posted March 18 Thanks for the pictures and explanations. Very nice! Ive never seen a tape guide, and tape tensioner like that? Where do you buy things like that. Quote
Members Dave9111 Posted March 20 Author Members Report Posted March 20 I finally received some 3/4" milspec 4088 herringbone binding I bought off ebay. Usps ground now takes 10 days to get from CA to IN. I have a real binding platter I purchased off Amazon for $14. It has a roller bearing in a plastic disk. It spins on a stainless steel tube. Very little friction. Pretty good for $14. The disk was a bit small so I made a larger disk out of 1/8" masonite which can lay on the smaller disk. It works fine, spins freely. I setup the synchronized binder on the 1245 with a 3/4" folding head, which was about $10 off Ebay and wow! I feel like Im cheating! It just works. Binding with this setup is easy. I tried binding around some 2" inside and outside radius' and it was no big deal. And the stitching stayed in the right place on the tape while making the turns. I thought the 3/4" tape might be a challenge. Nope. 😃 Quote
kgg Posted March 20 Report Posted March 20 22 minutes ago, Dave9111 said: I thought the 3/4" tape might be a challenge. Half decent equipment can make all the difference. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members nylonRigging Posted March 21 Members Report Posted March 21 9 hours ago, Dave9111 said: I thought the 3/4" tape might be a challenge. Nope. 😃 You can challenge yourself o do better.. LOL... now take 3/4" and turn multiple 90 deg. corners around object, were both sides must be finish look .. Then do same with double needle. . Quote
Members Dave9111 Posted March 25 Author Members Report Posted March 25 Yes, proper equipment is needed! Ill have to try binding a square with 3/4". Now Im curious if I can do that! But I dont know if I want to setup my twin needle machine for binding. It has 1/4" gauge. And the existing feet wont work at all. Although it does look nice. 😀 Thanks! Quote
Members nylonRigging Posted March 26 Members Report Posted March 26 (edited) 23 hours ago, Dave9111 said: Yes, proper equipment is needed! Ill have to try binding a square with 3/4". Now Im curious if I can do that! But I dont know if I want to setup my twin needle machine for binding. It has 1/4" gauge. And the existing feet wont work at all. Although it does look nice. 😀 Thanks! Ya, you need to swap-out your 1/4" , to a ( 3/16") gauge needle setup for 3/4". But it pretty easy to do, if you ever decide to do it . Double-needle does look good though, It presents itself well in trimming out items with the 3/4" on raw exposed edges, pockets and things . So... I just planting the seed now in back of your Brain ...LOL Even the old Singer 112/212 'needle feeds' are pretty common, easy to find, and a lot of people overlook them in searching out a compound feed, Needle-Gauge sets are common found, and cheep for them. Just grab an old 112/212 when you run across one. Clean it up, set it up with a Raw-Edge 3/4" binder . The old Needle-feed Singers do a Very Nice job with both fabric and Leather. People really overlook them and never give them enough credit over compound feed with Leather. BUT they do an outstanding job . Here a good example in Pic. using needle-feed machine binding edge on leather. I just cut a scrap strip off 3/4", off some nice soft supple black leather, and threw it under one of my Needle-Feeds set-up for 3/4 raw edge binding . Also trimmed same cut of Black with some raw-edge Nylon grosgrain 3/4" . - - Edited March 26 by nylonRigging Quote
Members Dave9111 Posted March 27 Author Members Report Posted March 27 Thanks nylonRigging. That does look really nice. Quote
Members Dave9111 Posted October 29 Author Members Report Posted October 29 Hi Guys, so binding has been going fine on my Pfaff 1245 with the synchronized binder. Most of the things I work on are larger. A 24" x 12" cover is small. My Dad had a need for a small pouch he could wear on his belt. The pouch is only about 5 inches long by 3 inches tall. Really small for me. I made a couple, each time with improvements. I decided to bind the edges with 3/4" nylon 4088 tape. That went fine. But then I realized I didnt have a great way to finish the binding. I usually just run the binding over the beginning of the tape, then run it off the edge. Then burn/melt the tail off with a hot knife. Is there a better way? My crude method looks crude when done on a small piece. What fo you guys do? Small stuff is hard! Quote
Members nylonRigging Posted October 30 Members Report Posted October 30 7 hours ago, Dave9111 said: Hi Guys, so binding has been going fine on my Pfaff 1245 with the synchronized binder. Most of the things I work on are larger. A 24" x 12" cover is small. My Dad had a need for a small pouch he could wear on his belt. The pouch is only about 5 inches long by 3 inches tall. Really small for me. I made a couple, each time with improvements. I decided to bind the edges with 3/4" nylon 4088 tape. That went fine. But then I realized I didnt have a great way to finish the binding. I usually just run the binding over the beginning of the tape, then run it off the edge. Then burn/melt the tail off with a hot knife. Is there a better way? My crude method looks crude when done on a small piece. What fo you guys do? Small stuff is hard! I grabbed some scrap and did a few quick and dirty finish on 3/4" tape ending for example with folding pieces of 1-k cordura . and there probably other techniques also. You can just Hot Knife, cut . . You can do a double-back fold, and do a quick little zigzag or bar-tack . . you can do an inward 'tuck' fold finish . The double-fold over, and tack is pretty self-explanatory for a finish on the tail-end . Hot Knife, cut-off takes a little practice to make look clean, and also a good seal/melt . Also Nylon hot knifes different than if you using Polyester. Polyester binding. You can make both look good, but they melt/act a little differently. Personally I think nylon cuts melts nicer. The inward tuck fold on the finish. That is used a lot with ending finish. Also on binding where you bind a circumference and finish off running on top your starting point. There a couple ways you can do it, and there is some technique involved that takes a little practice . Main thing is you have to stop the binding a couple inches from the finish. leave the Needle or Needles in the plunge holding down the material . Then slide or fold back you binding Folder out of the way, and cut the binding leaving some binding to work with for making the fold-tuck. Then just sew the finish without using the Folder. Also there couple ways to work the binding with your under-tucking . You can just fold it as is, and fold inward. Or you can do a 'split' center-lengthwise in the tailing piece your tucking . - - - - Quote
