Members Yehdhdh Posted March 9, 2025 Members Report Posted March 9, 2025 Hi. I just purchased a commercial sewing machine it is an Aisin AD3310. I got a crazy question for you. Is it possible to sew in “reverse” on this machine? I thought in order to lock stitch you have to. If you look at the picture of my machine, is it missing a lever to engage “reverse?” If so, can I use a reverse polarity switch to reverse? Or can I get a part from a Toyota machine? any thoughts would help! thanks!! Quote
AlZilla Posted March 9, 2025 Report Posted March 9, 2025 I know nothing about that particular machine, but I don't see an obvious reverse. This isn't really an unusual situation, generations of sewists never had reverse. This post describes "poor mans reverse", aka just what everyone used to do anyway: I have a couple of older machines w/o reverse and it's really no big deal. Welcome to the forum! Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted March 9, 2025 Report Posted March 9, 2025 (edited) 39 minutes ago, Yehdhdh said: Is it possible to sew in “reverse” on this machine? Yes but it requires you to turn the item as per a poor mans reverse. 39 minutes ago, Yehdhdh said: I thought in order to lock stitch you have to. No, a lot of lockstitch machines never had a reverse level think of the old Singers. 39 minutes ago, Yehdhdh said: If you look at the picture of my machine, is it missing a lever to engage “reverse?” From your photo it appears to never had a reverse lever. 39 minutes ago, Yehdhdh said: If so, can I use a reverse polarity switch to reverse? No. kgg Edited March 9, 2025 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Michiel Posted March 9, 2025 Members Report Posted March 9, 2025 (edited) Just a guess: Have you tried pushing the button you use to set the stitch length? Edited March 9, 2025 by Michiel Quote
AlZilla Posted March 9, 2025 Report Posted March 9, 2025 Well, now I want to go push that button. Here's a manual for a Toyota AD3310 that has reverse, but it's electrically controlled: https://www.supsew.com/wpfb-file/toyota-ad3310-series-pdf/ Aisin is a Japanese company - maybe their 3310 is a budget version. Push that button, @Yehdhdh ! Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
1hp Posted March 10, 2025 Report Posted March 10, 2025 on my 206rb5, the reverse lever shaft is on the right side of the head. there is a hole near your bobbin winder in a similar spot. Quote
