Members Rockrz Posted April 25, 2025 Author Members Report Posted April 25, 2025 31 minutes ago, fredk said: You could try using a wet strap for the conchos. Pull it up tight wet. Then when it dries out it will be even tighter I never thought of that but it makes sense that it would be tighter. How long to soak the strap in water? Maybe over night? Quote
Contributing Member fredk Posted April 25, 2025 Contributing Member Report Posted April 25, 2025 Naa, it should only take a few minutes, 30 mins at most. Use warm water, with a tiny wee bit of dish-washing liquid soap in it. After soaking stretch it along its length in your hands, squeeze out excess water then lace it through the holes. As it dries it will stiffen up and shrink a wee bit tightening up You can do this whether the strap is dyed or not Quote Al speling misteaks aer all mi own werk..
Members Rockrz Posted April 25, 2025 Author Members Report Posted April 25, 2025 OK, thanks. It's black so I'm assuming it's dyed unless it came from a black cow. Quote
