Members PMDLeather Posted March 27 Members Report Posted March 27 (edited) I've had my sewing machine for about six months (cowboy 797). It worked great until yesterday when I tried sewing. (On the leather) The bottom strand wasn't sewing, it was just a string holding the top strand in place. I could pull it out, and it wasn't threaded through a stitch. Has anyone run into this problem and know how to fix it? Edited March 27 by PMDLeather Quote
Northmount Posted March 27 Report Posted March 27 2 minutes ago, PMDLeather said: I've had my sewing machine for about six months (cowboy 797). It worked great until yesterday when I tried sewing. (On the leather) The bottom strand wasn't sewing, it was just a string holding the top strand in place. I could pull it out, and it wasn't threaded through a stitch. Has anyone run into this problem and know how to fix it? Check any changes to the top tension. Make sure the thread is properly seated between the tension disks. What changed? Increase the top tension if the only thing you did different was sew leather instead of something else, or thicker or harder leather. Changes in needle or thread also affect the tension. You need enough top tension to pull the knot up into the leather. Quote
Members PMDLeather Posted March 27 Author Members Report Posted March 27 Just now, Northmount said: Check any changes to the top tension. Make sure the thread is properly seated between the tension disks. What changed? Increase the top tension if the only thing you did different was sew leather instead of something else, or thicker or harder leather. Changes in needle or thread also affect the tension. You need enough top tension to pull the knot up into the leather. I'll try that now. Not much changed, I re-strung the top strand/thread but it's all correctly strung. Quote
Members PMDLeather Posted March 27 Author Members Report Posted March 27 8 minutes ago, Northmount said: Check any changes to the top tension. Make sure the thread is properly seated between the tension disks. What changed? Increase the top tension if the only thing you did different was sew leather instead of something else, or thicker or harder leather. Changes in needle or thread also affect the tension. You need enough top tension to pull the knot up into the leather. Just adjusted the tension, and it's working great now! Thank you!! Quote
Members PMDLeather Posted March 27 Author Members Report Posted March 27 @NorthmountNow I'm having another problem 🥴 Once I'm finished sewing, my bottom strand is coming out with two strands of thread, almost like it's getting tangled or something down there? Quote
Members PMDLeather Posted March 27 Author Members Report Posted March 27 On the cowboy 0797, once I'm finished sewing the bottom strand comes out with two or more pieces of thread. Does anyone know what's happening? Quote
AlZilla Posted March 27 Report Posted March 27 Well, without a lot of context to go on, I'll relate a similar experience with my 111W class machines. I was having on and off problems where the bottom stitches would get tangled and the workpiece would pull out from under the needle hard. There would be 2 or 3 strands of thread coming out of the needle plate. Finally I noticed that when that happened, my needle thread was split on the hook. It turned out I was holding my threads back way too hard when I was starting to sew. I only hold back lightly now and haven't had a problem since. You'll see advice here to "hold the threads back hard". But I think that applies to larger machines, like the CB4500 and such. Maybe someone else will comment. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted March 27 Report Posted March 27 43 minutes ago, PMDLeather said: On the cowboy 0797, once I'm finished sewing the bottom strand comes out with two or more pieces of thread. What size and type of thread are you using?? How thick of leather are you trying on sewing??? What size of needle are you using??? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members PMDLeather Posted March 27 Author Members Report Posted March 27 4 minutes ago, kgg said: What size and type of thread are you using?? How thick of leather are you trying on sewing??? What size of needle are you using??? kgg The size and type of thread and needle are the ones sent to me with the machine. The leather thickness is 6-7oz Quote
Northmount Posted March 27 Report Posted March 27 3 hours ago, PMDLeather said: @NorthmountNow I'm having another problem 🥴 Once I'm finished sewing, my bottom strand is coming out with two strands of thread, almost like it's getting tangled or something down there? Turn the handwheel a little further until the take up lever is all the way to the top before you pull the piece out from under the foot. Quote
