Members Piko Posted March 29 Members Report Posted March 29 I ended up getting this speed reducer. Now I am trying to figure put where to put it to drill the least amount of holes. If I install it like in the picture, I just have to move the motor over by an inch or 2 so possibly drilling just one hole (for the motor). But I lose the bobbin winder. If I placed it between the machine and the motor instead, I would need to move the motor further away from the machine drilling 3 holes for it but I would retain the bobbin winder. i am thinking of the first setup and loading the bobbin using a battery operated bobbin winder i purchase online. But it would be noce to also have the mechanical bobbin winder functional as it saves time. Anyone can think if a way to install the bobbin winder with the set up in the photo? Also, how do I measure the size of the belts I will need? One of them will have to be very small. Thank you in advance. Quote
Members nylonRigging Posted March 30 Members Report Posted March 30 (edited) Motor pulley belts to the Large pulley reducer, Small pulley reducer belts to machine hand wheel . 1st align smallest pulley reducer to sew heads hand wheel pulley, and drill, and bolt down . Then move drive motor to the align to the Large pulley of the reducer and drill and bolt down . Also, don't forger that you always have option to flip-over the Servo drive to Right or Left, as you have option to switch drive direction on the controller. Edit Add: .. that extra small carrier pulley on the bottom of the Sew Head for factory drive belt routing . Do you actually need this now ? Edited March 30 by nylonRigging Quote
Members Piko Posted March 30 Author Members Report Posted March 30 Got it, thank you!!! Yeah I don’t think i need that small wheel anymore, good point. I’ll see if I can remove it. Thank you again. Quote
kgg Posted March 30 Report Posted March 30 (edited) 19 hours ago, Piko said: Anyone can think if a way to install the bobbin winder with the set up in the photo? I don't think you are going to get the bobbin winder installed with the motor and reducer pulley mounted on the top of the table. My approach would be a more conventional method of mounting the motor and speed reducer on the underside of the table top. Cut a long slot probaly about 6" long for the machine belt directly below the sewing machine handwheel inline with the belt pulley part of the handwheel. The belt would be straight down through the table top to the small pulley of the speed reducer. The bobbin winder would be then installed pretty much as it was before installing a speed reducer. 19 hours ago, Piko said: Also, how do I measure the size of the belts I will need? One of them will have to be very small. Once you choose which way you want to approach installing the speed reducer either on top of the table top or below and you have the speeder reducer installed. I would take length of string and wrap it like a belt would be around the pulleys, measure the length and add 2 inches to get the length of the belt needed. kgg Edited March 30 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Constabulary Posted March 30 Members Report Posted March 30 when the motor is behind the machine you may have problems tilting back the machine for service / oiling. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
