Members ElNino Posted February 20, 2008 Members Report Posted February 20, 2008 (edited) I am trying to source a protecto board or equivalent here in Spain could somebody tell me what poundo board is made of or what I could use instead of, I'm thinking maybe a good piece of cork board but I don't think it will be dense enough. How thick should it be? Cheers, Chris Edited February 20, 2008 by ElNino Quote
Members Rawhide Posted February 20, 2008 Members Report Posted February 20, 2008 You can use a soft pine board, A cork board would work, provided it's thick enough. You can also use a poly board instead (kitchen cutting board). It's harder than poundo, but it's soft enough not to damage your tools. Marlon Quote Marlon
Members ElNino Posted February 20, 2008 Author Members Report Posted February 20, 2008 You can use a soft pine board, A cork board would work, provided it's thick enough. You can also use a poly board instead (kitchen cutting board). It's harder than poundo, but it's soft enough not to damage your tools.Marlon Marlon, Thanks, could you tell me what a Poundo board is made of and how thick it should be, I'm picturing a stiff rubber pad which will allow tool points to penetrate without dulling or bending the tip. Knotty Pine is about all you can get here so that's not going to be a good choice. Cheers, Chris Quote
Members Rawhide Posted February 20, 2008 Members Report Posted February 20, 2008 Chris, Sorry I forgot to answer that question. Yes, poundo is a fairly stiff rubber pad about 1/4" to 3/8" thick. If you have a Wal-mart or something of the sort, That poly board I mentioned could be the ticket. Like I said before, it is harder than the poundo, but will treat your tools the same way, plus it's eaiser to tell when you've punched all the way through the leather. Marlon Quote Marlon
esantoro Posted February 20, 2008 Report Posted February 20, 2008 Chris,Sorry I forgot to answer that question. Yes, poundo is a fairly stiff rubber pad about 1/4" to 3/8" thick. If you have a Wal-mart or something of the sort, That poly board I mentioned could be the ticket. Like I said before, it is harder than the poundo, but will treat your tools the same way, plus it's eaiser to tell when you've punched all the way through the leather. Marlon I think I'll start using the softer poly boards for pounding out holes and pounding off strap ends. It's too easy to pound through the poundo boards, but I do like them to put underneath my granite slabs. ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Members ElNino Posted February 20, 2008 Author Members Report Posted February 20, 2008 (edited) Chris,Sorry I forgot to answer that question. Yes, poundo is a fairly stiff rubber pad about 1/4" to 3/8" thick. If you have a Wal-mart or something of the sort, That poly board I mentioned could be the ticket. Like I said before, it is harder than the poundo, but will treat your tools the same way, plus it's eaiser to tell when you've punched all the way through the leather. Marlon Marlon, Thanks again. My book order should be arriving any day now so I will try and keep the dumb questions to the minimum Cheers, Chris Edited February 20, 2008 by ElNino Quote
Members Rawhide Posted February 20, 2008 Members Report Posted February 20, 2008 No questions are dumb my friend. That's why we are all here....to learn. Marlon Quote Marlon
TracyMoss Posted February 20, 2008 Report Posted February 20, 2008 As I was once told, "No dumb questions, just dumb people asking them." No offense, just thought it was funny. We are all here to learn from each other. Quote
Members ElNino Posted February 20, 2008 Author Members Report Posted February 20, 2008 As I was once told, "No dumb questions, just dumb people asking them."No offense, just thought it was funny. We are all here to learn from each other. I'll have to remember that one :w00t: Quote
Moderator Johanna Posted February 20, 2008 Moderator Report Posted February 20, 2008 I ususally put a piece of scrap leather under my punches, on top of the poundo board. Might just be superstition, but I think it helps the tools keep their edges better. Johanna Quote You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
