kgg Posted May 17 Report Posted May 17 15 hours ago, Freak_NL said: I guess I'll bite the bullet and order me some side With NL in your forum name I am going to assume you are from the Rock, the old country. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Freak_NL Posted May 17 Author Members Report Posted May 17 5 minutes ago, kgg said: With NL in your forum name I am going to assume you are from the Rock, the old country. Nope. No rock (or mountains for that matter). Just clay below sea level. Quote
Members Freak_NL Posted August 27 Author Members Report Posted August 27 Two months ago I made another belt incorporating the advice given here. These photos are after two months of wear. Here I used strips of 6 oz leather cut from a half hide, starting from the back. The belt has a strip of 0.6 mm reinforcement sheet sandwiched in the middle with a margin of about 5mm from the edges. I hand stitched the belt (in addition to glueing). Overall I am not dissatisfied with the end result. It is, at the very least, a functional belt. There is none of the bunching up from my first post, only some deforming of the tongue where the buckle sits. Eventually I intend to make a simple belt single layer belt out of a piece of 8/9 oz side to see how that works out. The thickness seems to be the cause of me misjudging the belt's length a little. As you can see my standard wear hole is the second one instead of the (ideal) third out of five. For this buckle this 12 oz thickness is a bit too much I feel, so my next attempt will use two 4 oz strips. Quote
AlZilla Posted August 27 Report Posted August 27 That buckle has quite a bend where it comes out of the belt. That may be causing some of it. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
CFM chuck123wapati Posted August 27 CFM Report Posted August 27 (edited) 3 hours ago, Freak_NL said: Two months ago I made another belt incorporating the advice given here. These photos are after two months of wear. Here I used strips of 6 oz leather cut from a half hide, starting from the back. The belt has a strip of 0.6 mm reinforcement sheet sandwiched in the middle with a margin of about 5mm from the edges. I hand stitched the belt (in addition to glueing). Overall I am not dissatisfied with the end result. It is, at the very least, a functional belt. There is none of the bunching up from my first post, only some deforming of the tongue where the buckle sits. Eventually I intend to make a simple belt single layer belt out of a piece of 8/9 oz side to see how that works out. The thickness seems to be the cause of me misjudging the belt's length a little. As you can see my standard wear hole is the second one instead of the (ideal) third out of five. For this buckle this 12 oz thickness is a bit too much I feel, so my next attempt will use two 4 oz strips. Nice looking work !! yeah 12 oz is pretty thick unless it's a tool or work belt. your buckle isn't made for that thickness; you can see it doesn't have a big enough bend on the bar end. I'll add a longer buckle would also help the bend problem or a hook and loop type buckle might even get you back to the middle hole. Edited August 27 by chuck123wapati brain fart Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Freak_NL Posted August 28 Author Members Report Posted August 28 19 hours ago, chuck123wapati said: I'll add a longer buckle would also help the bend problem or a hook and loop type buckle might even get you back to the middle hole. Not a bad idea. I think I'll give a longer buckle a go. Quote
Members Freak_NL Posted August 30 Author Members Report Posted August 30 On 8/27/2025 at 2:49 PM, chuck123wapati said: I'll add a longer buckle would also help the bend problem or a hook and loop type buckle might even get you back to the middle hole. That was spot on. I replaced the buckle, and that basically fixed this belt. Quote
CFM chuck123wapati Posted August 30 CFM Report Posted August 30 2 hours ago, Freak_NL said: That was spot on. I replaced the buckle, and that basically fixed this belt. Awesome!!! I am glad, folks don't always think about how and why buckles are shaped the way they are but they are designed for certain size belt straps and are overlooked quite often in the belt making process. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
