Members Yukonrookie Posted May 16 Members Report Posted May 16 Hello folks, I’m about to order some contact adhesive again and am debating between the above mentioned options from Renia. Although I’m pretty set on one of the above, I’m open to good alternatives. It’s gonna be used for sheaths, the odd holster, belts, hopefully the odd saddle and such. So it’ll have to withstand some wet moulding. Although the wet moulding I do would be more on the “light” to “medium” side. I will also say upfront that I contacted Renia and they recommended one of the above mentioned ones. So some would wonder why I still ask this question. Well, I’d like to know what experience those of you who used some or all of these contact adhesives made. I’d like a really strong bond with some resistance to water. I was a bit concerned people would get annoyed with me for asking this question, when I already got a recommendation from the manufacturer. I’ll take my chances anyways . These glues aren’t cheap and I personally don’t think it hurts to try and find out more about what and why people ,who actually used them, prefer one glue over the other. I appreciate you taking the time to read my post and possibly even give some feedback. It’s greatly appreciated. Quote
kgg Posted May 16 Report Posted May 16 10 hours ago, Yukonrookie said: I’m about to order some contact adhesive again Why not good old fashion LePage Heavy Duty contact cement??? I use it all the time, readily available, smells terrible, usually requires two coats with the first soaking into and sealing the leather and the second coat, once the first coat is dry, for bonding and can be thinned. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Contributing Member Samalan Posted May 16 Contributing Member Report Posted May 16 BARGE CONTACT, IT HAS NEVER FAILED ME. Quote
Digit Posted May 16 Report Posted May 16 At school and at home I use a water-based CA. I have no experience with anything else, but I'm happy with the water-based stuff I use (Ecostick 9015st): it hardly smells and it does its job, namely keeping pieces together until they're stitched. I'd never rely on glue alone to keep things together; you always have to sew to make it last. Then again, I have no experience (yet) with wet molding. Is molding glued-together pieces a thing? Most of the stuff I see here look as if they're molded first and then glued/sewn together... Quote
Members Yukonrookie Posted May 16 Author Members Report Posted May 16 5 hours ago, kgg said: Why not good old fashion LePage Heavy Duty contact cement??? I Yup, it’s sure cheaper and easier available. What colour is it when dry? Thanks a lot for the advice! Quote
kgg Posted May 16 Report Posted May 16 2 hours ago, Yukonrookie said: Yup, it’s sure cheaper and easier available. What colour is it when dry? The best I can figure is an off yellow. The color really shouldn't matter as you should never see it when you are gluing two pieces together just be careful not to put too much close to the edges. When making a belt I use two layers of 6 1/2 oz leather glued together, as I like a heavier belt and then stitch along both outside edges with V138. When I wet mould I do that before putting the pieces together then decide whether to glue, use double sided 1/4 binding tape or just sew. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Yukonrookie Posted May 17 Author Members Report Posted May 17 @Digit I do use water based CA as well sometimes (Aqualim315). Just with some projects where I wet mould after assembly, and sewing, I don’t like using it. Also where the item is exposed to moisture and heavy use outdoors on a regular basis I found it not to stand up to snuff. This is also based upon advisement by the one pro leatherworker who I know personally. Some of the sheaths I made so far were easiest to wet mould after assembly. Usually when the knife, especially the hilt, is a bit more on the smaller side. After I glued and stitched I’d just briefly pour water in it and dump it out immediately and place the wrapped knife inside it. Worked great. Of course some sheaths and especially holsters I would weld mold prior to assembly. I found that the water based glue doesn’t stand up well to moisture long after it dried and cured completely. So with sheaths and holsters with a welt the glue will detach all the way to the stitch line. Even though that’s only 1/8” to absolutely max 1/4”, depending on the project. Am I overthinking this? I do t know, but I think some projects a water based CA is the answer but for others a solvent based might be the better solution. I haven’t tried doubles sided tape yet. Quote
Members Yukonrookie Posted May 17 Author Members Report Posted May 17 Thanks for all the replies. I think I will go and give the Syntic Total a try. That’s what was recommended by Renia. If anyone uses it I’d love to hear your feedback, but I will probably go ahead with ordering it soon. Quote
Members Tastech Posted May 17 Members Report Posted May 17 From my experience as a shoe maker the Renia is over kill for what you are doing . Colle de colone is good for shoe repairs because it dries quick and can be used for many incompatible materials such as rubber to leather and rubber to PVC and rubber to polyurethane. It can get a bit stringy out of the pot and usually needs a bit of thinning using xylene . Not to mention the price . I generally use run of the mill contact cement for most jobs and renia when PVC or polyurethane are involved . Gluing leather to leather is easier and much cheaper using a regular contact . The shoe repair glue is the same formula only a thicker consistency than barge for example . Renia is not any stronger than the basic shoe contact i use but is 3 times the price . Its only advantage as i stated above is that it works on incompatible materials but even then when the correct primer is used. Quote
Members Yukonrookie Posted May 17 Author Members Report Posted May 17 15 minutes ago, Tastech said: Not to mention the price . I generally use run of the mill contact cement for most jobs Hey Tastech, thanks for the reply. When compared to I.e. weldwood, barge, masters etc. the difference to Syntic Total, for example, isn’t as big as I thought. At least in Canada. Weldwood is $45,95 and Syntic is $59,95. Still a 14 bucks difference and if I used up a quart bi-weekly, or even less, it’s quite a bit. For me a quart would last me a couple to three months. That said, the likes of Weldwood and barge are easier to get on a regular basis up here. If there’s no real difference between them, for just leather, then they‘ll be my choice after all. Weldwood (red) is especially quick and easy to get for me. Would you say that’d be a good choice? Quote
