Members RehsEmporium Posted May 27, 2025 Members Report Posted May 27, 2025 Hello there! I’m new and started “working” with leather not so long ago (would be a pleasure to see you on instagram if you are there I’m @rehsemporium ) Anyway, I’m currently making some leather dog collars and would like to change something in my finish process. After I’ve tooled , dyed , painted my piece of leather would it be right if I : seal it with BeeNatural Leather RTC antique with fiebing antique paste seal it again with fiebing snow proff paste ? Or (I’ve never used RTC yet so I don’t know how it work ) if RTC makes the paint come off : seal the painted area (I use Angelus paints) with a coat of Angelus 4 coat seal with beenatural RTC antique snow proof ? I’ve used tan Kote as resistant and finish but I realized It’s not really the best for dog collars, it’s not waterproof, it does not actually seal the piece …. thank you so much ! P.S I know that trying things out is the best way to find a good result, but I’m in Italy and it’s not really easy to find specific products, actually, except for leather , I’m buy supplies outside Italy , so before buying any suggestions would be great Quote
Northmount Posted May 28, 2025 Report Posted May 28, 2025 6 hours ago, RehsEmporium said: seal it with BeeNatural Leather RTC seal it again with fiebing snow proff paste These are leather conditioners and don't seal the surface. Quote
Members Dwight Posted May 28, 2025 Members Report Posted May 28, 2025 Resolene is THE sealer . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members RehsEmporium Posted May 28, 2025 Author Members Report Posted May 28, 2025 1 hour ago, Dwight said: Resolene is THE sealer . . . May God bless, Dwight Yeah , I know about Resolene , but I was hoping in something different 😅 I just wanted to give a more ‘natural look’ and that the piece could be oiled over time … but it seem like I should go with resolene thank you ! 🙏🏻 😊 Quote
Members RehsEmporium Posted May 28, 2025 Author Members Report Posted May 28, 2025 3 hours ago, Northmount said: These are leather conditioners and don't seal the surface. Read around the internet good stuff about them … actually wanted to go with BeeNatural Leathercare RTC - antique - then BeeNatural ‘leather finish’ , but I cannot find the last one anywhere here I know they may be less “stronger” than finishes like resolene , but seemed to be good products for a more natural finish (now I’m wondering if Angelus finishes may work as Resolene does ) thank you for answering! Quote
Members TomE Posted May 28, 2025 Members Report Posted May 28, 2025 Depends on your goal for "sealing" the leather. Compared to Resolene, Tan-Kote is less shiny and allows penetration of water, oils and conditioners. I avoid Resolene for tack and outdoor items because it wears off and leaves an uneven finish. Tan-Kote adds a litte shine while allowing the tack to be maintained by cleaning, conditioning, etc. Quote
Members RehsEmporium Posted May 28, 2025 Author Members Report Posted May 28, 2025 4 hours ago, TomE said: Depends on your goal for "sealing" the leather. Compared to Resolene, Tan-Kote is less shiny and allows penetration of water, oils and conditioners. I avoid Resolene for tack and outdoor items because it wears off and leaves an uneven finish. Tan-Kote adds a litte shine while allowing the tack to be maintained by cleaning, conditioning, etc. Yeah,watched lots of videos , even this one , and read so many things … and personally I don’t like the Resolene look so much . I’m also more for finishes the still allows you to condition the leather . In fact I’ve been using tan kote - antique - tank kote, and I’m good with it ! (if there are painted ares , I seal only those part first with an acrilic finish -Angelus 4 coat satin - cause I noticed tan kote remove a bit of paint ) But since it’s about dog collars I’m afraid that under the rain/snow/or whatever, the collar can be ruined easily, or that antique or dye can come off … so wanted to seal them in a better/waterproofing way but still be able to oil them once in a while, in order to have a long lasting item for this last dog collar after the final coat of tank kote , I put a neatfoot oil/beeswax mix (like a balm I made) it’s not bad but … I also read about Sno-seal , but it seems like it darken leather and makes it more rigid sorry for the long text 😅 I’m really trying to figure out the best way and not having the possibility to easily have access to some products make it harder. thank you so much for answering ! (Started to think I was the only one not liking Resolene that much 😂) Quote
Members TomE Posted May 29, 2025 Members Report Posted May 29, 2025 14 hours ago, RehsEmporium said: Yeah,watched lots of videos , even this one , and read so many things … and personally I don’t like the Resolene look so much . I’m also more for finishes the still allows you to condition the leather . In fact I’ve been using tan kote - antique - tank kote, and I’m good with it ! (if there are painted ares , I seal only those part first with an acrilic finish -Angelus 4 coat satin - cause I noticed tan kote remove a bit of paint ) But since it’s about dog collars I’m afraid that under the rain/snow/or whatever, the collar can be ruined easily, or that antique or dye can come off … so wanted to seal them in a better/waterproofing way but still be able to oil them once in a while, in order to have a long lasting item for this last dog collar after the final coat of tank kote , I put a neatfoot oil/beeswax mix (like a balm I made) it’s not bad but … I also read about Sno-seal , but it seems like it darken leather and makes it more rigid sorry for the long text 😅 I’m really trying to figure out the best way and not having the possibility to easily have access to some products make it harder. thank you so much for answering ! (Started to think I was the only one not liking Resolene that much 😂) For me, the key is educating clients about the maintenance of leather items used outdoors. Some do a good job and their items last a long time. Quote
