Members kytim Posted June 7 Members Report Posted June 7 Does anyone know where I can find the heavy duty robots used to attach a metal hammer loop to the leather? Quote
Members Dwight Posted June 7 Members Report Posted June 7 (edited) Look on Ebay . . . copper rivets . . . https://www.ebay.com/itm/352511867169?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20231107084023%26meid%3D0d1f268ea5e74b5c84712fb55d99b4c2%26pid%3D101875%26rk%3D4%26rkt%3D4%26sd%3D352656754562%26itm%3D352511867169%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimVIDwebV3WithCPCExpansionEmbeddingSearchQuerySemanticBroadMatchSingularityRecallReplaceKnnV4WithVectorDbNsOptHotPlRecallCIICentroidCoviewCPCAuto%26brand%3DUnbranded&_trksid=p2332490.c101875.m1851&itmprp=cksum%3A3525118671690d1f268ea5e74b5c84712fb55d99b4c2|enc%3AAQAKAAABkG96wQ16jds4VFcrhy1F3d4mbwZUJI9Fs%2BgdXYAHIzlX2e3YaNh7x%2BEnKA3G%2BCqSl1Xn4McfcWFK1GytmS2qxJ87mtE8Gm3iR1Ja4WBwh0hNHJrJx3Ki5mp04ow4CO7lP%2BooCybZDDU%2BbbSwmg7CbTin%2BBzBzbCYVnbjvyQAHu6--HI4MB7SvJl5IJqlyvomgoLMlgT6qAJzX0SANJhty2dLNihoUJlF8VqAlqljdRi835uzdT%2FRw2dvDZ%2FKGbQCHYRB14v0kGwE3cSXw%2B2qhe%2B0H%2F1j8myQUlVEX3joNhwh7qOrSJOdzneyRFZuDtxGj41Mo4ttFpvmPdZnY7DNvrzgPZCIDLjXsrwahFpin7FtgWogJyNJJFhlkZOSSgeqjgV%2FE6qC577KxRtf3aqZZ0MdG4rIUuSNO3m0nywm82cOYvXRVnn69oHwxBnnQ0KjnMpyrigJIETey1stdnFqzITxjP1rL6sGbvwarZEpOM1iVBWuTfedF6PWlN7ZXF9L4SBY50J8Wnr10iexzh033FM%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JX5ZZDZP9HHYXS3MDAEYDAG9 Cut a piece of 8 or 10 oz . . . about 7 inches long. Push the ends together . . . . then overlap the top corners . . . and swing the bottom corners of each end up so they are level with the top edge of the loop of leather. Put three rivets in it . . . in a triangle pattern . . . with the point at the top. That is the VERY BEST way to hang a hammer loop off a nail apron. I usually put a 8 or 9 inch piece that goes straight up from the loop we talked about . . . and fold it over the belt . . . with two snaps. it's THE most comfortable and easiest to use May God bless, Dwight Edited June 7 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
