Members dikman Posted July 19, 2025 Members Report Posted July 19, 2025 Thanks mate, it's fitted pretty tight, I'm not sure anything could penetrate and I don't want to force it. If I really want to bother I'll just buy another one as they're even cheaper than when I bought this! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Northmount Posted July 20, 2025 Report Posted July 20, 2025 2 hours ago, dikman said: Thanks mate, it's fitted pretty tight, I'm not sure anything could penetrate and I don't want to force it. If I really want to bother I'll just buy another one as they're even cheaper than when I bought this! Try heating it up fairly hot. Often that will soften Loctite and other thread lockers (and many glues / adhesives). Quote
Members dikman Posted July 21, 2025 Members Report Posted July 21, 2025 Err, this is attached directly to the pump assembly/battery/electronics, I don't think getting it hot enough to soften the thread locker is a good idea. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members mbnaegle Posted July 22, 2025 Author Members Report Posted July 22, 2025 Here's what I ended up with on the cordless compressor. @dikmanit sounds like your compressor is like mine. It had some kind of white thread locker material as well, but I was able to twist it loose. One mine, the top shell of the compressor unthreads, so if you need to put some heat on the fitting, you can do so without effecting the plastic parts inside. One mine, both ends of the top fitting were odd-ball, so I bought a Badger (M5) male to Paasche female adapter, as the Paasche thread was a little smaller than what was on top of the compressor fitting. I used my lathe to turn down the compressor fittings threads and re-thread them to match the Paasche adapter (about .256"x40tpi). It's not the tightest fit, but the rubber o-ring that comes with the adapter sealed it. The compressor fitting's inside diameter was a little too big to cut it all the way down to a Badger thread and avoid the adapter. It works! Time to pass it on to the kiddo. Quote
Members dikman Posted July 22, 2025 Members Report Posted July 22, 2025 This is mine, it's more of a rectangular body so the top doesn't appear to unscrew. I think I'll leave well enough alone. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
