Contributing Member Regis Posted December 18, 2007 Contributing Member Report Posted December 18, 2007 I've always keep a string loaded with rouge attached to my jewelers bench for a multitude of small polishing tasks. BUT, never thought of if for keeping edger sharp. Thanks. Attached to bench allows you to pull string tight while polishing. Another little trick an old guy taught me was to pull some cord (thread) through jewelers rouge. then pull the "loaded" string through your edger as many times as needed to keep your edger sharp.Marlon Quote God, Family, and Country (although liberals are attempting to destroy these in the USA)
Members Rawhide Posted December 18, 2007 Members Report Posted December 18, 2007 Hey, We just learned something from each other. Thanks and you're welcome at the same time. Quote Marlon
esantoro Posted December 20, 2007 Report Posted December 20, 2007 Here's a page from Stohlman's book on using and caring for leathercraft tools. It seems to illustrate what some have pointed out in this thread . I have also realized how important it is to sharpen edgers. The different is as between night and day. The attached page shows the need to take a file or sanding stone to the bottom of the edger. So far I have been using 600 emory paper on the top side only in fear of dulling the cutting edge. The tandy edgers are good to practice on, as I'd hate to mess up a more expensive edger. ed sharpen_edgers.pdf sharpen_edgers.pdf Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
esantoro Posted December 20, 2007 Report Posted December 20, 2007 I'd like to hear more about using a dremel to sharpen these edgers and know which attachments to use. Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Members Skipknives Posted December 20, 2007 Members Report Posted December 20, 2007 whee haw,,thanks guys,,and thank you for the pdf,,that helped too Quote Skip Slocum Phoenix Arizona http://skpslocum.googlepages.com/home
