paffaf sewing machine with 240 V motor & air compressor
Hi all
I got a paffaf sewing machine with 240 V motor & air compressor is there any quick solution to operate it other than pull new electrical lines from the main panel
Thanks
Edited by Northmount
Changed title to reflect content
Slipped this over to leather sewing machines.
It might make a difference which Pfaff you got. If it's a standard industrial with the motor under the table, swapping the motor out might solve part of it.
If it doesn't care about the source of it's compressed air, a small contractor compressor might be the rest of the solution.
- Voltaire
- Aristotle
More info always helps, along with photos. Pfaff makes a lot of machines.
  • Northmount changed the title to paffaf sewing machine with 240 V motor & air compressor
