Members JZC Posted September 9 Members Report Posted September 9 I just designed a logo so I can start stamping my work. I have a line in the logo that is 2.8 pt, so before I go any further I just want to make sure this will be visible/clear when stamped. I'm new to stamping so any help is appreciated! Thank you! Quote
RockyAussie Posted September 9 Report Posted September 9 Best I can tell 2.8 point is just under 1mm and from my experience 1.2mm is a good minimum width for clear stamping but this depends on the overall stamp somewhat. Thinner at the end of lines and in some texts it can still work fine. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members TomE Posted September 9 Members Report Posted September 9 The folks at The Steel Stamp Co tweaked my logo to make a small impression. Very happy with their work. Quote
Members JZC Posted September 9 Author Members Report Posted September 9 Ok, good to know. I will bump up the line pt 1.2mm. I was assuming that wherever you buy the stamp would advise to any necessary change for a clean impression. I will check out The Steel Co. If there is anyone else that has a favorite stamp co I would to check them out. Quote
Northmount Posted September 9 Report Posted September 9 11 hours ago, JZC said: I just designed a logo so I can start stamping my work. I moved your post to Stamping Quote
